メインコンテンツにスキップ
2008 Suzuki SX4 Brake Light Replacement
必要な工具と部品
  1. 2008 Suzuki SX4 Brake Light Replacement, Brake Light: 手順 1、 3の画像 1 2008 Suzuki SX4 Brake Light Replacement, Brake Light: 手順 1、 3の画像 2 2008 Suzuki SX4 Brake Light Replacement, Brake Light: 手順 1、 3の画像 3
    • Power off your vehicle before beginning the replacement.
    • With your vehicle in PARK, engage the emergency parking brake.
    • Turn off your vehicle and make sure all light switches are set to OFF.
  2. 2008 Suzuki SX4 Brake Light Replacement: 手順 2、 3の画像 1 2008 Suzuki SX4 Brake Light Replacement: 手順 2、 3の画像 2 2008 Suzuki SX4 Brake Light Replacement: 手順 2、 3の画像 3
    • Press the button located under the rear handle and above the license plate to open the hatch.
    • Open the hatch fully to expose the screws on the side of the brake light housing.
    • Open the hatch wide enough to give yourself some space while working on this replacement.
  3. 2008 Suzuki SX4 Brake Light Replacement: 手順 3、 2の画像 1 2008 Suzuki SX4 Brake Light Replacement: 手順 3、 2の画像 2
    • Using a Phillips head screwdriver, remove the two 5 mm bolts from the side of the brake light housing.
  4. 2008 Suzuki SX4 Brake Light Replacement: 手順 4、 3の画像 1 2008 Suzuki SX4 Brake Light Replacement: 手順 4、 3の画像 2 2008 Suzuki SX4 Brake Light Replacement: 手順 4、 3の画像 3
    • There are two clips behind the housing.
    • Be gentle when removing the brake light housing. The two clips behind the housing can break easily if you are not careful!
    • Gently pull the brake light housing towards you until it detaches from your car.
  5. 2008 Suzuki SX4 Brake Light Replacement: 手順 5、 3の画像 1 2008 Suzuki SX4 Brake Light Replacement: 手順 5、 3の画像 2 2008 Suzuki SX4 Brake Light Replacement: 手順 5、 3の画像 3
    • The bulbs can reach high temperatures during operation. Do not handle the bulbs if your vehicle has been in use recently!
    • Twist each bulb-connector to the left to unfasten the bulb from the housing.
    • Repeat this step for each bulb so that you can fully remove the housing.
    • This will give you better access to each bulb.
  6. 2008 Suzuki SX4 Brake Light Replacement: 手順 6、 3の画像 1 2008 Suzuki SX4 Brake Light Replacement: 手順 6、 3の画像 2 2008 Suzuki SX4 Brake Light Replacement: 手順 6、 3の画像 3
    • The brake light bulb has a nougat-colored connector.
    • Remove the brake light bulb from its connector by pulling it out of the socket.
    • Do not put too much pressure on the bulb with your hands. It is fragile and can shatter easily.
  7. 2008 Suzuki SX4 Brake Light Replacement: 手順 7、 3の画像 1 2008 Suzuki SX4 Brake Light Replacement: 手順 7、 3の画像 2 2008 Suzuki SX4 Brake Light Replacement: 手順 7、 3の画像 3
    • Place the new bulb into the socket.
    • If you are replacing the brake light with an LED Fog Light, ensure it is facing the correct orientation.
    • Unlike halogen bulbs, LED Bulbs only function when oriented correctly. You may need to reverse the orientation if the bulb is not functioning.
  8. 2008 Suzuki SX4 Brake Light Replacement: 手順 8、 3の画像 1 2008 Suzuki SX4 Brake Light Replacement: 手順 8、 3の画像 2 2008 Suzuki SX4 Brake Light Replacement: 手順 8、 3の画像 3
    • To ensure your bulbs are fully functional, depress the brake pedal. Doing this will make the brake lights turn on.
    • Make sure the light bulb turns on. This will also make sure your LED light is working properly.
    • Do not hold the brake pedal for too long as it will raise the temperature of the bulb to a dangerous level. Always wait for the bulb to cool down before handling it.
終わりに
To reassemble the housing, follow these instructions in reverse order. Once everything is reassembled, turn on all your vehicle lights and ensure all rear lights are functioning.
作成者
1人の作成者と共同作成されました。
Jesus Mendoza
メンバー登録日: 10/24/23
157 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 1-57, Briggs Fall 2023 CSU Los Angeles, Team 1-57, Briggs Fall 2023人のメンバー
CSULA-BRIGGS-F23S1G57
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 78
今までの合計 250
