メインコンテンツにスキップ
2008 Subaru Impreza Windshield Wiper Arm Adjustment
必要な工具と部品
  1. 2008 Subaru Impreza Windshield Wiper Arm Adjustment, 2008 Subaru Impreza Windshield Wiper Arm Adjustment: 手順 1、 1の画像 1
    • To begin, pop open your hood for best access.
  2. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: 手順 2、 1の画像 1
    • There will be a rectangular bolt cover on the end of the wiper arm.
    • To remove this cover, grab each side with your fingers and pull upward.
    • It may help to wedge your fingernails underneath the cover piece.
  3. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: 手順 3、 1の画像 1
    • After removing the bolt cover, you will find the bolt that holds the wiper arm onto the vehicle.
  4. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: 手順 4、 1の画像 1
    • Loosen the bolt with the socket wrench just enough to be able to move the arm up and down the windshield.
    • To loosen with the wrench, place the socket directly on top of the bolt and turn counter clockwise.
  5. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: 手順 5、 1の画像 1
    • Adjust the windshield wiper arm such that it is in the proper resting position.
  6. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: 手順 6、 1の画像 1
    • There should be approximately 2 inches of space between the bottom of the windshield and the wiper in proper resting position.
  7. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: 手順 7、 1の画像 1
    • Once the arm is in correct position, tighten the same bolt at the bottom of the arm to keep the wiper in place.
    • To tighten the bolt, place the socket directly on top of the bolt and turn in clockwise position until you are no longer able to turn.
  8. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: 手順 8、 1の画像 1
    • Place the bolt cover back over the bolt and push it down into clipped position.
  9. 2008 Subaru Impreza Windshield Wiper Arm Adjustment: 手順 9、 1の画像 1
    • Close the hood of the vehicle. Your windshield wiper should now be in the correct position.
終わりに
This guide will allow you to adjust both of the front windshield wipers. To realign the passenger side wiper, follow these steps in correct order.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Brianna Koski
メンバー登録日: 03/22/16
128 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team 1-15, Lauer Spring 2016 Michigan Tech, Team 1-15, Lauer Spring 2016人のメンバー
MTU-LAUER-S16S1G15
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 4,208
