メインコンテンツにスキップ
2008 Honda Pilot Tail Light Assembly Replacement
必要な工具と部品
  1. 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: 手順 1、 2の画像 1 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: 手順 1、 2の画像 2
    • Open the vehicle's trunk to see the two bolts holding the assembly to the body.
    • Remove the two 8 mm bolts using either a Phillips head screwdriver or socket wrench.
    • Save the bolts! They will be needed for installing the new assembly.
  2. 2008 Honda Pilot Tail Light Assembly Replacement: 手順 2、 2の画像 1 2008 Honda Pilot Tail Light Assembly Replacement: 手順 2、 2の画像 2
    • Place both hands on the assembly and pull it away from the vehicle.
    • There are two clips on the back of the assembly that are connecting it to the vehicle. They will disengage if the assembly is pulled with adequate force.
    • If the clips won't disengage try using a rocking motion while pulling on the assembly.
  3. 2008 Honda Pilot Tail Light Assembly Replacement: 手順 3、 3の画像 1 2008 Honda Pilot Tail Light Assembly Replacement: 手順 3、 3の画像 2 2008 Honda Pilot Tail Light Assembly Replacement: 手順 3、 3の画像 3
    • Unlock the three light sockets connected to the assembly by twisting them counter clockwise.
    • Pull the light sockets out of the assembly.
  4. 2008 Honda Pilot Tail Light Assembly Replacement: 手順 4、 3の画像 1 2008 Honda Pilot Tail Light Assembly Replacement: 手順 4、 3の画像 2 2008 Honda Pilot Tail Light Assembly Replacement: 手順 4、 3の画像 3
    • Set the old assembly aside.
    • Take the new assembly, and put the light bulb sockets into their corresponding holes.
    • Twist each socket clockwise to lock them into place.
  5. 2008 Honda Pilot Tail Light Assembly Replacement: 手順 5、 3の画像 1 2008 Honda Pilot Tail Light Assembly Replacement: 手順 5、 3の画像 2 2008 Honda Pilot Tail Light Assembly Replacement: 手順 5、 3の画像 3
    • Line the clips on the back of assembly up with their holes, and push the assembly into place.
    • Take the bolts from Step 2 and place them into the holes on the new assembly. Twist them clockwise until secure.
  6. 2008 Honda Pilot Tail Light Assembly Replacement: 手順 6、 1の画像 1
    • Congratulations! You have installed a new tail light assembly on your vehicle!
終わりに
Congratulations! You have successfully completed the guide! Enjoy your new tail light assembly.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
John Forsyth
メンバー登録日: 11/12/20
163 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S2-G20, Kim Fall 2020 University of Memphis, Team S2-G20, Kim Fall 2020人のメンバー
UM-KIM-F20S2G20
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 557
