メインコンテンツにスキップ
2008 BMW 335xi Blower Motor Replacement
必要な工具と部品
  1. 2008 BMW 335xi Blower Motor Replacement, Blower Motor: 手順 1、 3の画像 1 2008 BMW 335xi Blower Motor Replacement, Blower Motor: 手順 1、 3の画像 2 2008 BMW 335xi Blower Motor Replacement, Blower Motor: 手順 1、 3の画像 3
    • Put the passenger seat all the way back to create as much room as possible.
    • Remove any objects from the floor of the passenger seat so that you have a clean workspace.
  2. 2008 BMW 335xi Blower Motor Replacement: 手順 2、 2の画像 1 2008 BMW 335xi Blower Motor Replacement: 手順 2、 2の画像 2
    • Remove the panel on the right side of the trunk to expose the battery.
    • Twist the knob to unlatch the door so that you can remove it.
  3. 2008 BMW 335xi Blower Motor Replacement: 手順 3、 3の画像 1 2008 BMW 335xi Blower Motor Replacement: 手順 3、 3の画像 2 2008 BMW 335xi Blower Motor Replacement: 手順 3、 3の画像 3
    • Use a 10mm socket wrench to loosen the bolt and remove the negative battery terminal.
    • Then tuck it to the right side and wrap it in a rag.
    • This prevents the circuit from being accidentally completed while you continue working.
  4. 2008 BMW 335xi Blower Motor Replacement: 手順 4、 3の画像 1 2008 BMW 335xi Blower Motor Replacement: 手順 4、 3の画像 2 2008 BMW 335xi Blower Motor Replacement: 手順 4、 3の画像 3
    • Remove the two T20 Torx screws located below the glove box.
    • One is located all the way on the right and the other one is located all the way on the left.
    • The panel will drop down as the screws are removed. Pull the panel away slightly.
    • Careful not to let it drop all the way down as a wire is connected to the footwell light.
    • Disconnect the black cable for the footwell light.
  5. 2008 BMW 335xi Blower Motor Replacement: 手順 5、 3の画像 1 2008 BMW 335xi Blower Motor Replacement: 手順 5、 3の画像 2 2008 BMW 335xi Blower Motor Replacement: 手順 5、 3の画像 3
    • There is only one connecter that needs to be disconnected to remove the blower motor. This connector is black with two red/orange wires going into it.
    • Pinch the connector on the top and bottom and pull it out to remove it.
  6. 2008 BMW 335xi Blower Motor Replacement: 手順 6、 2の画像 1 2008 BMW 335xi Blower Motor Replacement: 手順 6、 2の画像 2
    • Pull down on the tab towards the front of the car and at the same time turn the whole assembly clockwise.
    • Pull the round black assembly out from the vehicle.
    • This is the blower motor assembly!
    • When pulling the blower motor out, be careful not to drop it on yourself.
終わりに
To reassemble your blower motor, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Dhimitraq Lolo
メンバー登録日: 03/26/19
181 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S3-G11, Saloman Spring 2021 UMass Dartmouth, Team S3-G11, Saloman Spring 2021人のメンバー
UMASSD-SALOMAN-S21S3G11
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 23
過去 30 日: 77
今までの合計 3,174
