メインコンテンツにスキップ
2008-2010 Mitsubishi Lancer Radio/CD Player Replacement
必要な工具と部品
  1. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement, 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 1、 1の画像 1
    • The only tool required for this install is a Phillips #2 screwdriver. Of course, you will also need the new replacement radio/CD player unit that you will be installing.
    • Make sure that the car is not on before proceeding since we will be accessing some electrical components. However, you do not need to disconnect the car's battery.
  2. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 2、 2の画像 1 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 2、 2の画像 2
    • Using both hands, apply inward pressure to the sides of the glove compartment until the compartment is free to slide out.
    • The clips on the side of the glove compartment must be freed.
  3. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 3、 1の画像 1
    • Remove the attached plastic arm by simply pulling outward so that the arm snaps out of its socket.
  4. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 4、 2の画像 1 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 4、 2の画像 2
    • The glove compartment can now be removed completely by raising it off its hinges.
  5. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 5、 1の画像 1
    • Using the Philips #2 screwdriver, remove a 15 mm screw located just above the glove compartment damper piston.
  6. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 6、 1の画像 1
    • Carefully remove the plastic trim by pulling outwards.
  7. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 7、 1の画像 1
    • Using a Philips #2 screwdriver remove a 15 mm screw from the trim piece.
  8. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 8、 3の画像 1 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 8、 3の画像 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 8、 3の画像 3
    • Using both hands, carefully pull the trim outward section by section.
    • The dashboard and decorative trim are attached to each other, so they will come out as one unit.
    • When pulling out the trim start from the right and work your way toward the center console.
  9. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 9、 1の画像 1
    • Optional: If you choose, you can remove the harness shown. (See directions on Step 12 for removing a harness clip.) Otherwise you can simply rest the fixture on top of the shift knob.
  10. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 10、 1の画像 1
    • Using a Philips #2 screwdriver remove four 12 mm screws attached to the mounting bracket.
  11. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 11、 2の画像 1 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 11、 2の画像 2
    • Pull out the radio unit to expose the connections behind it.
  12. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 12、 2の画像 1 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 12、 2の画像 2
    • Remove the black antenna connection by simply pulling it out.
  13. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 13、 3の画像 1 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 13、 3の画像 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 13、 3の画像 3
    • Remove both the large and small wire harnesses by firmly pressing in and holding the retaining clip.
    • While continuing to hold down the retaining clip, firmly pull the harnesses out.
    • Do not pull harnesses out by the wires, as you may damage or break the wires. Instead pull out by the white plastic harness.
  14. 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 14、 3の画像 1 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 14、 3の画像 2 2008-2010 Mitsubishi Lancer Radio/CD Player Replacement: 手順 14、 3の画像 3
    • You are now ready to replace your radio with your new unit.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Carlos Esquivel
メンバー登録日: 02/23/15
236 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 12-1, Green Winter 2015 Cal Poly, Team 12-1, Green Winter 2015人のメンバー
CPSU-GREEN-W15S12G1
6 メンバー
7のガイドは作成済み
5 件のコメント
Thx. Saved me hrs of wrongful disassembly. Lol
Phil - 返信
Any Mitsubishi radio code can be recovered for free by online generating tool : https://www.radiocodescalculator.com/mit...
Blaze Angelov - 返信
Hi I own a 2008 Mitsubishi lancer just brought it CD player doesn't work only radio so wondering where I can buy a new stereo thanks. Or a way to fix mine it's like it's not working at all turn onto CD mode but won't even try read
JAD BLAXLAND - 返信
Had the same problem with my 08 lancer. Replaced with a refurbished unit.
sanjurjo54 -
If you break some of the white clips like i did, the replacement part number from Mitsubishi is MR402859
gregshep - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 32
過去 30 日: 117
今までの合計 19,592
