メインコンテンツにスキップ
2008-2013 Subaru Forester Cabin Air Filter Replacement
必要な工具と部品
  1. 2008-2013 Subaru Forester Cabin Air Filter Replacement, Cabin Air Filter: 手順 1、 1の画像 1
    • Ensure the vehicle is shut off with the key removed from the ignition before you begin.
    • Open the glovebox located on the passenger side.
  2. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 手順 2、 2の画像 1 2008-2013 Subaru Forester Cabin Air Filter Replacement: 手順 2、 2の画像 2
    • Unhook the glovebox retention arm from the side of the glovebox by squeezing the clip together with your fingertips, and prying the arm off the lower connection point only.
    • Gently push the arm up and half way in to prevent accidental breakage.
  3. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 手順 3、 2の画像 1 2008-2013 Subaru Forester Cabin Air Filter Replacement: 手順 3、 2の画像 2
    • Starting on either the left or right side, insert screwdriver blade tip into the small catch ramp until it releases.
    • Repeat inserting screwdriver blade tip on opposite side of glovebox and catch ramp until both sides are released and glovebox falls freely open.
  4. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 手順 4、 2の画像 1 2008-2013 Subaru Forester Cabin Air Filter Replacement: 手順 4、 2の画像 2
    • Remove the glovebox by pulling horizontally away from its (C shaped) hinge points.
  5. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 手順 5、 3の画像 1 2008-2013 Subaru Forester Cabin Air Filter Replacement: 手順 5、 3の画像 2 2008-2013 Subaru Forester Cabin Air Filter Replacement: 手順 5、 3の画像 3
    • Open door to filter compartment to access filter.
    • Remove filter media.
    • Note orientation of filter for reinsertion.
終わりに
Finally, to reinstall the clean cabin air filter, simply follow these same instructions, but in reverse order.
Purchasing and replacing your own cabin filter is simple, time-saving, and resourceful. Congratulations on a job well done!
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sean Mc
メンバー登録日: 09/26/18
175 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team S3-G3, Crane Fall 2018 Eastern Washington University, Team S3-G3, Crane Fall 2018人のメンバー
EWU-CRANE-F18S3G3
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 23
過去 30 日: 80
今までの合計 6,295
