必要な工具と部品
Drain oil from oil pan until flow comes to a slow drip.
Remove the oil filter from the Engine Oil Cooler assembly, and replace Oil Filter and O-Ring with new parts.
Tighten Oil Filter Cap down to 25 N-m.
Replace oil pan drain plug with new part and torque down to 14 N-m.
Pour 4.25 quarts of engine motor oil into by removing the oil filler cap on top of cylinder head.
Tighten oil filler cap down tightly.
ある他の人がこのガイドを完成しました。
