はじめに
Here it is o'dark thirty and mother in law got pulled over by the local sheriff for a broken indicator. Nice Guy, let her off with a warning. She wants it changed NOW. The large tail light assemblies on the Aveo contains the brake and parking lights, turn signal and the back up lights.
必要な工具と部品
Here is a view of the left tail light assembly
Open the rear hatch,( or trunk if it is a sedan). On the inside of the assembly are two retaining screws. Remove those
both screws are #6x3/4 inch
Here is a view of the assembly with the screws removed.
Insert some sort of prying tool between the tail light assembly and the body, just below the crease in the body and pry to the rear of the vehicle. a snap will be felt/heard as the plastic stud releases
Move the prying tool to above 1 1/2 inch above the bottom of the assembly. Insert it between the assembly and body and gently pry toward the rear of the vehicle. This should free the second stud.
7 の人々がこのガイドを完成させました。
