メインコンテンツにスキップ
2007-2011 Toyota Camry Sun Visor Replacement
必要な工具と部品
  1. 2007-2011 Toyota Camry Sun Visor Replacement, Sun Visor: 手順 1、 3の画像 1 2007-2011 Toyota Camry Sun Visor Replacement, Sun Visor: 手順 1、 3の画像 2 2007-2011 Toyota Camry Sun Visor Replacement, Sun Visor: 手順 1、 3の画像 3
    • Remove cap and squeeze metal brackets revealed underneath to loosen and remove from interior of car.
    • Make a note of where the clips of the lever arm fit into the interior of car for reinstatement of the visor later.
  2. 2007-2011 Toyota Camry Sun Visor Replacement: 手順 2、 2の画像 1 2007-2011 Toyota Camry Sun Visor Replacement: 手順 2、 2の画像 2
    • Tear open the seam surrounding the hole that the swing arm inserts into with a seam ripper.
    • Pull the fabric back to show the inner casing.
  3. 2007-2011 Toyota Camry Sun Visor Replacement: 手順 3、 2の画像 1 2007-2011 Toyota Camry Sun Visor Replacement: 手順 3、 2の画像 2
    • Reinsert the swing arm back into the visor, make sure the metal prongs on the swing arm line up with the holes on the visor.
    • The red squares show where the metal prongs fit into the holes of the visor.
  4. 2007-2011 Toyota Camry Sun Visor Replacement: 手順 4、 3の画像 1 2007-2011 Toyota Camry Sun Visor Replacement: 手順 4、 3の画像 2 2007-2011 Toyota Camry Sun Visor Replacement: 手順 4、 3の画像 3
    • Fold the aluminum plate around the outer casing to reinforce the arm in the casing.
    • The metal plate will hold both halves of the visor to the lever arm, so make sure it is secured tightly around visor to keep it together.
  5. 2007-2011 Toyota Camry Sun Visor Replacement: 手順 5、 1の画像 1
    • Screw a one inch screw through the metal plate and plastic casing using a phillips head screwdriver.
    • Make sure screw goes all the way through to the other side to effectively secure plate to visor.
  6. 2007-2011 Toyota Camry Sun Visor Replacement: 手順 6、 2の画像 1 2007-2011 Toyota Camry Sun Visor Replacement: 手順 6、 2の画像 2
    • Adhere the two halves of the torn seam back together over the outer casing and the aluminum plate​ using upholstery glue.
    • Allow the glue to properly dry before replacing visor back into car.
  7. 2007-2011 Toyota Camry Sun Visor Replacement: 手順 7、 3の画像 1 2007-2011 Toyota Camry Sun Visor Replacement: 手順 7、 3の画像 2 2007-2011 Toyota Camry Sun Visor Replacement: 手順 7、 3の画像 3
    • Realign the metal clips of the swing arm to the hole in the car and snap the visor back into place.
    • If you go back to step one, the hinges are marked to show where the insert the swing arm.
終わりに
15 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Kimberly Reilly
メンバー登録日: 02/23/16
327 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team 26-5, Rauch Spring 2016 Texas Tech, Team 26-5, Rauch Spring 2016人のメンバー
TTU-RAUCH-S16S26G5
3 メンバー
3のガイドは作成済み
25 件のコメント
How do you remove the visor from the swing arm to begin?
Is there any electrical work you need deal with? it looks like in the first pick there are some wires hanging from the swing arm that I am guessing power the light
Nick - 返信
For future readers: simply remove the visor from the ceiling as described in step one. No need to separate the visor from the swing arm in advance. Proceed through the steps as described. I used a 3x5 tie plate (http://www.homedepot.com/p/Simpson-Stron...) and it worked beautifully. I screwed the plate (2nd row of holes) to the edge of a piece of wood about the same thickness as the visor and bend it around that wood as a guide. It resulted in the 1st and 3rd rows of holes aligning so that I could put the screws all the way through and secure with lock nuts. I used #6-32, 1.5" screws (2) and #6-32 locknuts (2). The holes in the tie plate were ever so slightly too small for those screws but a drill bit one size too large for the hole widened it perfectly with ease. The screws were too long (1" was too short) and needed to be cut off with a dremel afterwards. (I couldn't find a 1.25" length screw for the job.)
Dylan Valliere - 返信
Well, for most of us the visor has completely fallen off of the swing arm already, so it's a non-issue. But thanks for the condescending reply to the OP who took the time to write an incredibly helpful review.
Betsy Rogers -
This is a Toyota design flaw. It is a safety issue and is negligence on their part not to admit failure and issue recalls. This is in no way isolated to the Camry. It occurs in RAV4s, Tacomas, Highlander's, Tundras and possibly more.
serbirish - 返信
My wife's 2012 Venza has this problem, as does my 2011 Camry.
Nevins Parkinson -
コメントを追加
統計データ:
過去 24時間: 20
過去 7 日: 115
過去 30 日: 385
今までの合計 120,536
