メインコンテンツにスキップ
2007-2012 Jeep Wrangler Headlight Replacement
必要な工具と部品
  1. 2007-2012 Jeep Wrangler Headlight Replacement, Headlight: 手順 1、 2の画像 1 2007-2012 Jeep Wrangler Headlight Replacement, Headlight: 手順 1、 2の画像 2
    • Locate the two gray latches on either side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. 2007-2012 Jeep Wrangler Headlight Replacement: 手順 2、 2の画像 1 2007-2012 Jeep Wrangler Headlight Replacement: 手順 2、 2の画像 2
    • Reach under the hood and push the lever left to right. You should now be able to lift the hood.
    • Prop open the hood by inserting the support rod into the designated hole on the underside of the hood.
  3. 2007-2012 Jeep Wrangler Headlight Replacement: 手順 3、 3の画像 1 2007-2012 Jeep Wrangler Headlight Replacement: 手順 3、 3の画像 2 2007-2012 Jeep Wrangler Headlight Replacement: 手順 3、 3の画像 3
    • Locate all six push on fasteners on the top of the grill.
    • Use a flathead screwdriver to pry up the fasteners, and make sure you put the screws somewhere safe.
    • If the fasteners will not come up, use two flathead screwdrivers on either side of the fastener to remove.
  4. 2007-2012 Jeep Wrangler Headlight Replacement: 手順 4、 3の画像 1 2007-2012 Jeep Wrangler Headlight Replacement: 手順 4、 3の画像 2 2007-2012 Jeep Wrangler Headlight Replacement: 手順 4、 3の画像 3
    • Locate right and left blinker lights under the fenders.
    • Twist blinker light toward the ground, and make sure you pull the bulb out carefully.
    • Make sure you are handling bulb carefully.
  5. 2007-2012 Jeep Wrangler Headlight Replacement: 手順 5、 3の画像 1 2007-2012 Jeep Wrangler Headlight Replacement: 手順 5、 3の画像 2 2007-2012 Jeep Wrangler Headlight Replacement: 手順 5、 3の画像 3
    • Make sure all fasteners are removed from top of the grill, and the top of the grill is loose.
    • Firmly pull the bottom of the grill until the grill disconnects from the jeep.
  6. 2007-2012 Jeep Wrangler Headlight Replacement: 手順 6、 2の画像 1 2007-2012 Jeep Wrangler Headlight Replacement: 手順 6、 2の画像 2
    • Locate the 4 screws holding the headlight in place.
    • Use a star bit screwdriver to unscrew the .164-18 x .625 mm star bit screws around the headlight, and make sure you place screws somewhere safe.
    • Hold the headlight when unscrewing last screw to prevent the headlight from falling.
  7. 2007-2012 Jeep Wrangler Headlight Replacement: 手順 7、 2の画像 1 2007-2012 Jeep Wrangler Headlight Replacement: 手順 7、 2の画像 2
    • Use your hands to carefully remove silver ring from the headlight.
  8. 2007-2012 Jeep Wrangler Headlight Replacement: 手順 8、 3の画像 1 2007-2012 Jeep Wrangler Headlight Replacement: 手順 8、 3の画像 2 2007-2012 Jeep Wrangler Headlight Replacement: 手順 8、 3の画像 3
    • Locate red tab on the headlight plug connector, and push it away from the headlight.
    • Firmly pull the connector away from headlight to remove.
終わりに
6 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Marco Santini
メンバー登録日: 09/29/15
290 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-3, Green Fall 2015 Cal Poly, Team 17-3, Green Fall 2015人のメンバー
CPSU-GREEN-F15S17G3
4 メンバー
3のガイドは作成済み
3 件のコメント
Could Jeep make it more difficult to do simple maintenance? I doubt it!
Linda Procida - 返信
What is that green connector called? I’m having trouble putting new lights because none of the converters fit.
Alex - 返信
What it is the recommended torque to screw it back?
Luis Vitorio Cargnini - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 44
今までの合計 21,162
