メインコンテンツにスキップ
2007-2012 Acura Rdx Tail Light Bulb Replacement
必要な工具と部品
  1. 2007-2012 Acura Rdx Tail Light Bulb Replacement, Tail Light Bulb: 手順 1、 1の画像 1
    • Open the trunk.
  2. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 2、 1の画像 1
    • Clean the area of work by removing any materials in the area.
  3. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 3、 2の画像 1 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 3、 2の画像 2
    • Remove the bolt covers with the flat head screwdriver from the tail light housing.
  4. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 4、 2の画像 1 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 4、 2の画像 2
    • Remove bolts with a ratchet, driver extension bar, and 5/16" socket from tail light housing.
    • If a ratchet, drive extension bar, and 5/16" socket are not available, a Phillips head screwdriver can be used as a substitute. However, using a Phillips head screwdriver will make the removal of the bolts more challenging.
  5. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 5、 2の画像 1 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 5、 2の画像 2
    • Remove tail light housing from the car.
  6. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 6、 1の画像 1
    • Remove the bulb socket from the tail light housing.
  7. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 7、 1の画像 1
    • Remove the bulb from bulb socket.
  8. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 8、 1の画像 1
    • Insert new bulb into bulb socket.
  9. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 9、 1の画像 1
    • Check the new bulb is functioning.
  10. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 10、 1の画像 1
    • Insert bulb socket back into tail light housing.
  11. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 11、 1の画像 1
    • Insert tail light housing back into car.
  12. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 12、 1の画像 1
    • Insert bolt back into the tail light housing with a ratchet, driver extension bar, and 5/16" socket.
    • If a ratchet, drive extension bar, and 5/16" socket are not available, a Phillips head screwdriver can be used as a substitute. However, using a Phillips head screwdriver will make the tightener of the bolts more challenging.
  13. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 13、 2の画像 1 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 13、 2の画像 2
    • Insert bolt covers into the tail light housing.
  14. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 14、 1の画像 1
    • Check that the tail light housing is secured.
  15. 2007-2012 Acura Rdx Tail Light Bulb Replacement: 手順 15、 1の画像 1
    • Double check the new bulb is functioning.
終わりに
Driving a vehicle without the tail lights working is a violation against traffic laws and doing so could result in a traffic fine. Another important factor is the safety of passengers present on the road because driving a vehicle with inadequate visibility could result in an accident since the stopping sight distance will be affected dramatically. Therefore, it is important to have working tail lights. Nevertheless, the average price of replacing a tail light bulb on 2007-2012 Acura Rdx vehicles is approximately between 90 to 100 dollars after tax. Nonetheless, if the driver knows how to replace a tail light bulb on 2007-2012 Acura Rdx vehicles, they can do it for around a tenth of the cost expected from automobile repair shops. The only things to keep in mind when following the steps above is to make sure not to stick the screwdriver or your fingers in the taillight bulb socket to avoid being electrocuted or, serious damage can be caused to the electrical components of the vehicle. In addition, make sure not to perform the fix during wet conditions.
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
JONG HUN KIM
メンバー登録日: 06/20/18
331 ポイント
1ガイドが承認済み
チーム
Washington State, Team S1-G2, Hope Summer 2018 Washington State, Team S1-G2, Hope Summer 2018人のメンバー
WSU-HOPE-SU18S1G2
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 70
今までの合計 6,588
