メインコンテンツにスキップ
2006 Toyota Tundra Side Mirror Replacement
必要な工具と部品
  1. 2006 Toyota Tundra Side Mirror Replacement, Side Mirror: 手順 1、 3の画像 1 2006 Toyota Tundra Side Mirror Replacement, Side Mirror: 手順 1、 3の画像 2 2006 Toyota Tundra Side Mirror Replacement, Side Mirror: 手順 1、 3の画像 3
    • Remove the plastic piece covering from the mirror bolts.
    • Place the flat head screwdriver behind the plastic covering for leverage.
    • Pop off the plastic piece to uncover all the hidden bolts.
  2. 2006 Toyota Tundra Side Mirror Replacement: 手順 2、 3の画像 1 2006 Toyota Tundra Side Mirror Replacement: 手順 2、 3の画像 2 2006 Toyota Tundra Side Mirror Replacement: 手順 2、 3の画像 3
    • Remove the first bolt.
    • Use the 10mm wrench to loosen the three bolts.
    • Loosen the bolts to the end but do not take the bolts off completely.
  3. 2006 Toyota Tundra Side Mirror Replacement: 手順 3、 3の画像 1 2006 Toyota Tundra Side Mirror Replacement: 手順 3、 3の画像 2 2006 Toyota Tundra Side Mirror Replacement: 手順 3、 3の画像 3
    • Remove the bolts by hand.
    • Place all the bolts in a secure location such as your pocket.
  4. 2006 Toyota Tundra Side Mirror Replacement: 手順 4、 2の画像 1 2006 Toyota Tundra Side Mirror Replacement: 手順 4、 2の画像 2
    • Once all the bolts are off, approach the other plastic mirror covering from the outside door.
    • Slowly pop off the plastic covering using your hands.
    • This process should be almost effortless to remove the piece.
  5. 2006 Toyota Tundra Side Mirror Replacement: 手順 5、 3の画像 1 2006 Toyota Tundra Side Mirror Replacement: 手順 5、 3の画像 2 2006 Toyota Tundra Side Mirror Replacement: 手順 5、 3の画像 3
    • Once the mirror is off, push the plastic covering back on.
    • Pinch the plastic covering from both sides with one hand to make sure it is in place.
    • Make sure to keep your window rolled down for this step.
  6. 2006 Toyota Tundra Side Mirror Replacement: 手順 6、 3の画像 1 2006 Toyota Tundra Side Mirror Replacement: 手順 6、 3の画像 2 2006 Toyota Tundra Side Mirror Replacement: 手順 6、 3の画像 3
    • Grab the bolts that were taken off on the second step and with your hands tighten the bolts as much as possible.
    • Repeat this step for all three bolts.
  7. 2006 Toyota Tundra Side Mirror Replacement: 手順 7、 3の画像 1 2006 Toyota Tundra Side Mirror Replacement: 手順 7、 3の画像 2 2006 Toyota Tundra Side Mirror Replacement: 手順 7、 3の画像 3
    • Grab the 10mm wrench and tighten the bolts till they cannot anymore.
  8. 2006 Toyota Tundra Side Mirror Replacement: 手順 8、 3の画像 1 2006 Toyota Tundra Side Mirror Replacement: 手順 8、 3の画像 2 2006 Toyota Tundra Side Mirror Replacement: 手順 8、 3の画像 3
    • From the first step, grab the first plastic covering that was taken off.
    • Align the piece with all three bolts (it should fit just like a puzzle piece).
    • Snap your plastic piece back in and give it a nice hit to make sure it is locked in till you hear a snap.
終わりに
作成者
1人の作成者と共同作成されました。
Milos Skrbic
メンバー登録日: 10/05/21
157 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 11-26, Grodsky Fall 2021 CSU Los Angeles, Team 11-26, Grodsky Fall 2021人のメンバー
CSULA-GRODSKY-F21S11G26
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 23
今までの合計 891
