はじめに
This guide will show how to replace a dead or dying battery in a Honda Shadow Spirit motorbike. All tools should be included in the motorbike in the tool box.
NOTE: The directions in the guide refer to the view from the back of the motorbike.
Left = The side opposite the tail pipe
Right = The side with the tail pipe
必要な工具と部品
Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
The tool box is located under the panel.
Using the key to the motorbike, unlock the tool box.
Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
Pull the rear of the seat upwards.
Pull the seat backwards to remove it from the bike.
Pull the cover off the battery and remove the fuse box from the cover.
Place the fuse box over to the side right of the bike. Do not disconnect the wires.
Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
Place the wire over the left side of the bike.
Also using the screwdriver, remove the positive (+) cable from the battery.
Place the wire over the right side of the bike.
9 の人々がこのガイドを完成させました。
