メインコンテンツにスキップ
2006 Honda Shadow Spirit 750 Battery Replacement
必要な工具と部品
  1. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove outer casing: 手順 1、 1の画像 1
    • Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
  2. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: 手順 2、 3の画像 1 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: 手順 2、 3の画像 2 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: 手順 2、 3の画像 3
    • The tool box is located under the panel.
    • Using the key to the motorbike, unlock the tool box.
    • Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
  3. 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: 手順 3、 2の画像 1 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: 手順 3、 2の画像 2
    • Using the allen wrench, remove the screws on both sides of the bike seat.
  4. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the seat: 手順 4、 1の画像 1
    • Pull the rear of the seat upwards.
    • Pull the seat backwards to remove it from the bike.
  5. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove plastic covering: 手順 5、 1の画像 1
    • Using the screwdriver, remove the screw holding the plastic cover.
  6. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the fusebox: 手順 6、 1の画像 1
    • Pull the cover off the battery and remove the fuse box from the cover.
    • Place the fuse box over to the side right of the bike. Do not disconnect the wires.
  7. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the ground wire: 手順 7、 1の画像 1
    • Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
    • Place the wire over the left side of the bike.
  8. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the power cable: 手順 8、 1の画像 1
    • Also using the screwdriver, remove the positive (+) cable from the battery.
    • Place the wire over the right side of the bike.
    • Do not let the red(+) and black(-) wires touch
  9. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the battery: 手順 9、 1の画像 1
    • Remove the battery from the bike by pulling upwards.
終わりに
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Dazarene Cascio
メンバー登録日: 10/07/14
736 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-7, Donnelly Fall 2014 USF Tampa, Team 1-7, Donnelly Fall 2014人のメンバー
USFT-DONNELLY-F14S1G7
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 18
過去 30 日: 73
今までの合計 18,765
