メインコンテンツにスキップ
2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement
必要な工具と部品
  1. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement, Throttle Position Sensor (TPS): 手順 1、 2の画像 1 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement, Throttle Position Sensor (TPS): 手順 1、 2の画像 2
    • Pull the release lever for the hood.
  2. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 2、 1の画像 1
    • Slide the latch under the center of the hood to the left and then open the hood.
  3. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 3、 1の画像 1
    • Disconnect the positive battery terminal by loosening the 10 mm nut and pulling the wire of the red battery terminal.
  4. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 4、 3の画像 1 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 4、 3の画像 2 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 4、 3の画像 3
    • Remove the connector attached to the TPS by sliding back the red clip and pulling.
  5. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 5、 1の画像 1
    • Use a T20 Torx screwdriver to remove the two bolts holding in the sensor.
  6. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 6、 2の画像 1 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 6、 2の画像 2
    • Remove the old TPS.
  7. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 7、 1の画像 1
    • Install the new TPS and put the two T20 Torx bolts back in.
  8. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 8、 1の画像 1
    • Connect the connector to the new TPS and make sure the red clip is pushed forward.
  9. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 9、 1の画像 1
    • Reconnect the positive battery terminal, by tightening the 10 mm nut and putting the red cover back over it.
  10. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 10、 1の画像 1
    • Close the hood and make sure it is closed securely.
  11. 2006 Ford Mustang 4.0L V6 Throttle Position Sensor (TPS) Replacement: 手順 11、 1の画像 1
    • Start the car and make sure that it is running normally.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Nathaniel Johnson
メンバー登録日: 03/16/21
220 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 70
今までの合計 3,211
