メインコンテンツにスキップ
2006 Ford F-150 Door Handle Cable Replacement
必要な工具と部品
  1. 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: 手順 1、 3の画像 1 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: 手順 1、 3の画像 2 2006 Ford F-150 Door Handle Cable Replacement, 2006 Ford F-150 Door Handle Cable Replacement: 手順 1、 3の画像 3
    • Remove the plastic cover from the door handle using a 7.6 cm slotted screwdriver.
    • Insert the screwdriver into the small opening found at the top of the plastic cover.
    • Carefully tilt the screwdriver upward to remove the plastic cover.
  2. 2006 Ford F-150 Door Handle Cable Replacement: 手順 2、 3の画像 1 2006 Ford F-150 Door Handle Cable Replacement: 手順 2、 3の画像 2 2006 Ford F-150 Door Handle Cable Replacement: 手順 2、 3の画像 3
    • Remove the two 6 mm hex screws using a 6mm socket.
    • Turn the screwdriver counter-clockwise to loosen and remove the screws.
    • Grab the door handle and remove it from its location.
  3. 2006 Ford F-150 Door Handle Cable Replacement: 手順 3、 3の画像 1 2006 Ford F-150 Door Handle Cable Replacement: 手順 3、 3の画像 2 2006 Ford F-150 Door Handle Cable Replacement: 手順 3、 3の画像 3
    • Remove the top plastic cover by pulling outward to snap it out of its location.
    • There are not any screws to remove in this part.
  4. 2006 Ford F-150 Door Handle Cable Replacement: 手順 4、 2の画像 1 2006 Ford F-150 Door Handle Cable Replacement: 手順 4、 2の画像 2
    • Remove the other plastic cover by pulling outward to snap it out of its location.
  5. 2006 Ford F-150 Door Handle Cable Replacement: 手順 5、 3の画像 1 2006 Ford F-150 Door Handle Cable Replacement: 手順 5、 3の画像 2 2006 Ford F-150 Door Handle Cable Replacement: 手順 5、 3の画像 3
    • Remove the three 6 mm hex screws off the main door cover using a 6 mm socket. There are two screws at the top and one at the bottom.
    • The panel itself should stay in place even after the screws have been removed.
    • The door panel is maintained in place by plastic hooks behind it.
  6. 2006 Ford F-150 Door Handle Cable Replacement: 手順 6、 3の画像 1 2006 Ford F-150 Door Handle Cable Replacement: 手順 6、 3の画像 2 2006 Ford F-150 Door Handle Cable Replacement: 手順 6、 3の画像 3
    • Gently, but with a strong force, lift the door cover about an inch or two high. Then, carefully pull it outward.
    • Be careful not to damage the plastic hooks that are keeping the door in place.
  7. 2006 Ford F-150 Door Handle Cable Replacement: 手順 7、 3の画像 1 2006 Ford F-150 Door Handle Cable Replacement: 手順 7、 3の画像 2 2006 Ford F-150 Door Handle Cable Replacement: 手順 7、 3の画像 3
    • Snap out the upper end of the cable out of its location.
    • The upper end of the cable has a shape of a little ball. The little ball is found by where the door handle was removed.
    • Using a plier, lift the cable high enough so that the little ball can come out through the round opening above it.
  8. 2006 Ford F-150 Door Handle Cable Replacement: 手順 8、 3の画像 1 2006 Ford F-150 Door Handle Cable Replacement: 手順 8、 3の画像 2 2006 Ford F-150 Door Handle Cable Replacement: 手順 8、 3の画像 3
    • Remove the three T27 hex star screws using a tamper torx screw driver. The screws are found at the bottom of the door.
    • You may need a mechanic creeper to lay under the door.
    • Wear protective goggles if you lay down under the door to do this step.
  9. 2006 Ford F-150 Door Handle Cable Replacement: 手順 9、 3の画像 1 2006 Ford F-150 Door Handle Cable Replacement: 手順 9、 3の画像 2 2006 Ford F-150 Door Handle Cable Replacement: 手順 9、 3の画像 3
    • Insert your hand inside the bottom of the door to retrieve the door latch.
  10. 2006 Ford F-150 Door Handle Cable Replacement: 手順 10、 1の画像 1
    • Remove the end of the cable out of its location.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Francisco Garcia
メンバー登録日: 01/22/17
164 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017人のメンバー
USFSM-STEWART-S17S1G1
19 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 38
今までの合計 2,171
