はじめに
If the blinker bulb on your Dodge Ram 2006 is not flashing, it may be due to a burnt bulb. Use this guide to help replace a burnt bulb. In step two, when you pull the light casing out, wires will be attached to the case. Please do not touch the wires as they are exposed electrical wires and may cause harm to you or the cables themselves.
必要な工具と部品
Remove the two screws securing the light to the truck using an Allen wrench.
もう少しです!
ゴール
