メインコンテンツにスキップ
2006-2013 Toyota Corolla Turn Signal Bulb Replacement
必要な工具と部品
  1. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement, Turn Signal Bulb: 手順 1、 2の画像 1 2006-2013 Toyota Corolla Turn Signal Bulb Replacement, Turn Signal Bulb: 手順 1、 2の画像 2
    • Pull the hood release lever towards yourself until the hood pops.
    • Open and move the bonnet lever towards the left to completely release the hood.
  2. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 2、 2の画像 1 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 2、 2の画像 2
    • Lift the prop and place it inside bonnet hole to keep the hood open.
    • The hood prop will be located towards the front of the engine.
  3. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 3、 2の画像 1 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 3、 2の画像 2
    • Turn your wheel to the appropriate side to locate the signal light.
    • For the left signal light, you would turn your wheel inwards to the right. While for the right side turn your wheel inwards by turning left.
  4. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 4、 3の画像 1 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 4、 3の画像 2 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 4、 3の画像 3
    • Pry off the clip under the wheel well using a flathead screwdriver.
    • Remove the lining by pulling it straight back.
    • Some cars are different and may need different tools. For example, some have nuts holding the liner so you'll need a wrench.
  5. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 5、 1の画像 1
    • Twist the signal housing counter-clockwise until it releases.
  6. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 6、 3の画像 1 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 6、 3の画像 2 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 6、 3の画像 3
    • With one hand grab the socket and with the other pull the bulb straight out of the socket.
  7. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 7、 3の画像 1 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 7、 3の画像 2 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 7、 3の画像 3
    • Insert the new bulb into the empty socket place the signal light back into the housing and twist it clockwise to the original position.
  8. 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 8、 3の画像 1 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 8、 3の画像 2 2006-2013 Toyota Corolla Turn Signal Bulb Replacement: 手順 8、 3の画像 3
    • Make sure your signal works properly by turning it on.
終わりに
作成者
2人の作成者と共同で作成されました。
Alexander
メンバー登録日: 10/24/23
157 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 8-1, Ribeiro Fall 2023 CSU Los Angeles, Team 8-1, Ribeiro Fall 2023人のメンバー
CSULA-RIBEIRO-F23S8G1
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 21
過去 30 日: 89
今までの合計 613
