はじめに
A dim or burnt-out brake light can potentially lead to automobile accidents as well as a ticket from law enforcement. If you have a 2013 Toyota Corolla or similar model, this guide can save you the trouble of going to an automobile service by helping you do it yourself. Be sure to disconnect the battery of the car, prior to beginning this repair.
必要な工具と部品
Open the trunk of the vehicle.
Locate the taillight area that needs fixing either on the right and/or left.
Rotate the brown socket counterclockwise and pull out the socket.
Pull the nonfunctioning light bulb from its socket and replace with the new, functioning bulb
Put the brown socket back in place and rotate clockwise to secure it
Put the covering back in place and secure the 3 fasteners. No tools are required, simply push the fasteners into position.
2 の人々がこのガイドを完成させました。
