メインコンテンツにスキップ
2006-2014 GMC Yukon LED Dome Light Replacement
必要な工具と部品
  1. 2006-2014 GMC Yukon LED Dome Light Replacement, Dome Light: 手順 1、 3の画像 1 2006-2014 GMC Yukon LED Dome Light Replacement, Dome Light: 手順 1、 3の画像 2 2006-2014 GMC Yukon LED Dome Light Replacement, Dome Light: 手順 1、 3の画像 3
    • locate the square slots furthest from the light switch and wedge the edge of the prying tool into the slot to pry out the hooks holding the lens in place.
  2. 2006-2014 GMC Yukon LED Dome Light Replacement: 手順 2、 2の画像 1 2006-2014 GMC Yukon LED Dome Light Replacement: 手順 2、 2の画像 2
    • The back two hooks have been removed from their slots; pull the lens out to get the front hooks out of their slots.
    • The LED light could be hot depending on the amount of time you had the light on.
    • If your lights have not been on, then feel free to pull the LED light out with your hand and replace it with your new one.
  3. 2006-2014 GMC Yukon LED Dome Light Replacement: 手順 3、 2の画像 1 2006-2014 GMC Yukon LED Dome Light Replacement: 手順 3、 2の画像 2
    • While removing the LED light you can either use a prying tool to hook the top edge of the LED and pull it down slowly or you can pull it down from the glass piece.
    • Insert your new LED light in the same place where the old one used to be.
    • Make sure that the copper components of the LED are aligned with the copper hooks that will keep the LED in place.
  4. 2006-2014 GMC Yukon LED Dome Light Replacement: 手順 4、 2の画像 1 2006-2014 GMC Yukon LED Dome Light Replacement: 手順 4、 2の画像 2
    • To put the lens back in, insert the hooks closes to the light switches into their respective slots first.
    • Insert the back two hooks in their respective slots.
    • You can use the prying tool to make it easier to insert the back two hooks in their slots.
終わりに
hope this guide has helped someone!
作成者
1人の作成者と共同作成されました。
J C
メンバー登録日: 09/24/23
115 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 1-3, Watkins Fall 2023 Austin Community College, Team 1-3, Watkins Fall 2023人のメンバー
AUSTINCC-WATKINS-F23S1G3
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 24
今までの合計 123
