はじめに
Weatherproofing car window for a convertible Ford Mustang 2006. This project will assist in providing a solution for people who have noticed a lot of wind noise in their car or water leaking inside the car. This guide will ensure people will have a good condition weatherproofing car window that is ready for any rain or snow or even car wash.
ツール
  1. Driver side weatherproofing car window.
    • Driver side weatherproofing car window.
  2. Locate the both ends of the weather stripping. Locate the both ends of the weather stripping.
    • Locate the both ends of the weather stripping.
  3. Pull down the weather stripping from the middle. Pull down the weather stripping from the middle.
    • Pull down the weather stripping from the middle.
  4. In each side of the weather stripping, you will find one plastic nail. Take off these two plastic nails with your hand.
    • In each side of the weather stripping, you will find one plastic nail.
    • Take off these two plastic nails with your hand.
  5. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  6. Remove the old weather stripping. Remove the old weather stripping.
    • Remove the old weather stripping.
  7. Clean any dust from where you took out the old weather stripping. Clean any dust from where you took out the old weather stripping.
    • Clean any dust from where you took out the old weather stripping.
  8. Bring the new weather stripping.
    • Bring the new weather stripping.
  9. Starting from both sides, push the two plastic nails into the holes.
    • Starting from both sides, push the two plastic nails into the holes.
  10. Push the weather stripping from the middle with your fingers.
    • Push the weather stripping from the middle with your fingers.
  11. Make sure it is aligned. Make sure it is aligned.
    • Make sure it is aligned.
まとめ
Abdelaziz Alqisy
メンバー登録日: 2018年09月25日
181 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team S3-G4, Crane Fall 2018 Eastern Washington University, Team S3-G4, Crane Fall 2018人のメンバー
EWU-CRANE-F18S3G4
4 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 44
