メインコンテンツにスキップ
2005 Mustang GT Serpentine Belt Tensioner Replacement
必要な工具と部品
  1. 2005 Mustang GT Serpentine Belt Tensioner Replacement, Serpentine Belt Tensioner: 手順 1、 1の画像 1
    • To open the hood, pull the hood latch located on the left side of the driver's foot well.
  2. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 2、 3の画像 1 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 2、 3の画像 2 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 2、 3の画像 3
    • Push a lever (located just above the horse in the grill) to the left.
    • Lift the hood up, pull the prop out, and insert it into the hole on the hood labeled "prop."
  3. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 3、 2の画像 1 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 3、 2の画像 2
    • Disconnect the battery using an 8 mm socket and 3/8 inch drive ratchet.
  4. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 4、 1の画像 1
    • Loosen the band clamp on the throttle body with a flathead screwdriver.
  5. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 5、 1の画像 1
    • Loosen the band clamp on the air filter or airbox.
  6. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 6、 3の画像 1 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 6、 3の画像 2 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 6、 3の画像 3
    • Pull the intake tube back and to the left to remove it from the throttle body and airbox.
    • Place the intake tube out of the way
  7. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 7、 1の画像 1
    • Make note of the orientation that the serpentine belt runs. If the tensioner is broken, and the belt is no longer on, refer to a diagram for the vehicle. If still attached, release tension on the belt using a 1/2 inch breaker bar turned in the clockwise direction and remove it.
  8. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 8、 1の画像 1
    • Remove the three 10 mm bolts with your 3/8 drive and 10 mm socket.
    • Remove the tensioner.
  9. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 9、 1の画像 1
    • Install the new tensioner and torque the bolts to 20ft lbs. then using the breaker bar turn clockwise to allow the reinstallation of the belt.
    • Using the breaker bar, turn clockwise to allow the reinstallation of the belt.
  10. 2005 Mustang GT Serpentine Belt Tensioner Replacement: 手順 10、 1の画像 1
    • Make sure all the grooves of the pullies are seated in the belt correctly, then release the tensioner to seat the belt.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Patrick Hall
メンバー登録日: 03/22/21
202 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S1-G9, Sinclaire Spring 2021 UMass Dartmouth, Team S1-G9, Sinclaire Spring 2021人のメンバー
UMASSD-SINCLAIRE-S21S1G9
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 54
今までの合計 2,426
