はじめに
The engine oil is used as a lubricant that prevents metal parts from rubbing together and overheating. Keeping your engine oil clean ensures a longer life for your vehicle.
必要な工具と部品
Identify the jack point, located directly underneath your car, in the center portion between the front two wheels.
Place the Hydraulic Jack beneath the jack point.
Pump the lever on the Hydraulic Jack, up and down, until the jack makes contact with the jack point. (Adjust the placement if necessary).
Continue pumping the lever until the wheels are two inches off the ground.
Identify the jack points located behind each front tire. Place a Jack Stand underneath both jack points.
Slowly rotate the Hydraulic Jack counter-clockwise to lower it. (Half a turn should be enough.)
After fully lowering the Hydraulic Jack, remove it from underneath your car.
Identify the open hood latch. It is located to the left of your brake pedal.
Pull latch toward you. You should hear a click from the front of the car.
Pull out the dipstick
Unscrew the cap from the oil tank
Set both aside. lay a towel over the engine block and set dipstick and the cap on that to avoid traces of oil.
Place oil pan between the front tires
Lay down and slide yourself headfirst under the front of the car. To the side of the right tire you will see the oil tank.
Loosen the drain bolt with a 17mm wrench. Once loose, use your hand to unscrew the rest of the way.
Allow oil to drain until the flow is reduced to a slow drip.
Replace the crush washer on the drain bolt with a new one.
Put the drain bolt back into the oil tank and tighten with 29 ft-lb of torque.
5 の人々がこのガイドを完成させました。
2件のガイドコメント
Well-done.
The only issue I have is that I don't have the tools.
The explanations are ok
