メインコンテンツにスキップ
2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement
必要な工具と部品
  1. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement, Heater Control Valve: 手順 1、 3の画像 1 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement, Heater Control Valve: 手順 1、 3の画像 2 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement, Heater Control Valve: 手順 1、 3の画像 3
    • Make sure your vehicle is off and your engine is completely cool before beginning.
    • Unlatch your hood by pulling the lever underneath the steering wheel.
    • Release the latch under the front of the hood.
    • Open the hood and insert the prop rod into the prop rod groove.
  2. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 2、 2の画像 1 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 2、 2の画像 2
    • Locate the regulator valve under the windshield wiper assembly, just in front of the firewall.
  3. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 3、 3の画像 1 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 3、 3の画像 2 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 3、 3の画像 3
    • Use pliers to squeeze the clamp tabs on the right side of the valve.
    • While squeezing the clamp tabs, pull the hose to the right to disconnect it from the valve.
  4. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 4、 2の画像 1 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 4、 2の画像 2
    • Take note of the original orientation of the valve before removal.
    • Use pliers to squeeze the clamp tabs on the left side of the valve.
    • While squeezing the left valve clamp tabs, disconnect the left side of the valve from the hose.
  5. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 5、 1の画像 1
    • With your replacement valve in your free hand, squeeze the clamp tabs on the left hose and insert the replacement valve into the hose.
    • Make sure the hose is pressed all the way against the valve.
    • If there is an arrow on your new valve, it should point away from the heat intake (the hose going into your vehicle's cabin).
  6. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 6、 1の画像 1
    • Ensure the clamp is snugly fit around the hose, and securely clamped down on the valve inside the hose, before you release the clamp tabs.
    • Leave about a quarter-inch gap between the clamp and the valve.
  7. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 7、 2の画像 1 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 7、 2の画像 2
    • While squeezing the clamp tabs on the right hose with pliers, insert the hose into the right side of the valve.
  8. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 8、 1の画像 1
    • Ensure the clamp is snug and squarely fit over the hose, and clamping down on the valve inside the hose, before you release the tabs.
    • Leave about a quarter inch gap between the clamp and the valve.
  9. 2005 Chrysler Town & Country 3.8L Heater Control Valve Replacement: 手順 9、 1の画像 1
    • Start your vehicle outdoors and let the engine run until it reaches its normal operating temperature.
    • Ensure there are no leaks around the valve.
終わりに
If there are leaks on the valve, repeat steps 1-9. Make sure the valve is in the correct orientation and the clamps are snug and properly secured. If a problem still occurs, there may be a hose leak in need of diagnosis and repair.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
John Hamer
メンバー登録日: 03/04/22
211 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team 2-16, Willis Spring 2022 University of Memphis, Team 2-16, Willis Spring 2022人のメンバー
UM-WILLIS-S22S2G16
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 99
今までの合計 3,515
