メインコンテンツにスキップ
2005-2010 Scion tC Liftgate Support Strut Replacement
必要な工具と部品
  1. 2005-2010 Scion tC Liftgate Support Strut Replacement, Liftgate Support Strut: 手順 1、 3の画像 1 2005-2010 Scion tC Liftgate Support Strut Replacement, Liftgate Support Strut: 手順 1、 3の画像 2 2005-2010 Scion tC Liftgate Support Strut Replacement, Liftgate Support Strut: 手順 1、 3の画像 3
    • Open the trunk hatch of the vehicle and have another person hold it in the fully open position.
    • Propping open the hatch with objects to replace the liftgate support struts can lead to serious injury and vehicle damage.
  2. 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 2、 3の画像 1 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 2、 3の画像 2 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 2、 3の画像 3
    • Insert the screwdriver underneath the clip located on the end of the strut connected to the hatch lid.
    • Pry the clip away from the strut.
    • Pull the strut to disconnect the socket from the ball joint on the hatch lid.
  3. 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 3、 3の画像 1 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 3、 3の画像 2 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 3、 3の画像 3
    • Insert the screwdriver underneath the clip located on the end of the strut connected to the vehicle body.
    • Pull the strut to disconnect the socket from the ball joint.
  4. 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 4、 3の画像 1 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 4、 3の画像 2 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 4、 3の画像 3
    • Begin the installation of the replacement strut with the ball joint located on the vehicle.
    • Place the socket around the ball joint.
    • Push the socket onto the ball joint until the metal clip clicks into place.
  5. 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 5、 3の画像 1 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 5、 3の画像 2 2005-2010 Scion tC Liftgate Support Strut Replacement: 手順 5、 3の画像 3
    • Align the replacement strut with the hatch lid.
終わりに
To replace blown liftgate support struts for a 2005-2010 Scion tC, follow these instructions.
作成者
3人の作成者と共同で作成されました。
Spenser Brown
メンバー登録日: 10/03/20
129 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S2-G1, Raign Fall 2020 University of North Texas, Team S2-G1, Raign Fall 2020人のメンバー
UNT-RAIGN-F20S2G1
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 42
今までの合計 1,422
