メインコンテンツにスキップ
2004-2007 Chevrolet Malibu Headlight Replacement
必要な工具と部品
  1. 2004-2007 Chevrolet Malibu Headlight Replacement, Removing Screws: 手順 1、 1の画像 1
    • First pop the hood of the car and locate the headlight. They are towards the front of the car.
  2. 2004-2007 Chevrolet Malibu Headlight Replacement: 手順 2、 3の画像 1 2004-2007 Chevrolet Malibu Headlight Replacement: 手順 2、 3の画像 2 2004-2007 Chevrolet Malibu Headlight Replacement: 手順 2、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the 10 mm screws attaching the headlight to the car.
  3. 2004-2007 Chevrolet Malibu Headlight Replacement, Take out the headlight: 手順 3、 2の画像 1 2004-2007 Chevrolet Malibu Headlight Replacement, Take out the headlight: 手順 3、 2の画像 2
    • Remove the headlight so you can see all wiring going from the car and to the headlight.
  4. 2004-2007 Chevrolet Malibu Headlight Replacement, Safety Caps: 手順 4、 2の画像 1 2004-2007 Chevrolet Malibu Headlight Replacement, Safety Caps: 手順 4、 2の画像 2
    • Remove the safety caps to get a good a view of your bulb wiring.
  5. 2004-2007 Chevrolet Malibu Headlight Replacement, Remove the Bulb: 手順 5、 1の画像 1
    • Turn the bulb counter clockwise then pull it out.
  6. 2004-2007 Chevrolet Malibu Headlight Replacement, Separate the bulb and pigtail: 手順 6、 2の画像 1 2004-2007 Chevrolet Malibu Headlight Replacement, Separate the bulb and pigtail: 手順 6、 2の画像 2
    • Pull back the clip that's holding the bulb (top half) and the pigtail (bottom half) together.
    • Pull apart the two, exposing the inside of the damaged pigtail.
  7. 2004-2007 Chevrolet Malibu Headlight Replacement, Cutting Wires: 手順 7、 3の画像 1 2004-2007 Chevrolet Malibu Headlight Replacement, Cutting Wires: 手順 7、 3の画像 2 2004-2007 Chevrolet Malibu Headlight Replacement, Cutting Wires: 手順 7、 3の画像 3
    • Now that you have separated the bulb and pigtail, detach the pigtail end from the car wires using wire cutters or scissors.
    • How To Cut With Wire Cutters
    • After cutting the wires, grab your new pigtail and pull back the rubber surrounding the wire. Pull back the rubber so there is enough wire to twist (connect) to the car wire.
  8. 2004-2007 Chevrolet Malibu Headlight Replacement, Electrical Tape: 手順 8、 3の画像 1 2004-2007 Chevrolet Malibu Headlight Replacement, Electrical Tape: 手順 8、 3の画像 2 2004-2007 Chevrolet Malibu Headlight Replacement, Electrical Tape: 手順 8、 3の画像 3
    • Once you've connected the pigtail back to the car be sure to wrap the wire in electrical tape.
    • Then grab your new bulb and attach it to the new pigtail by pushing it together until the clip has clicked.
    • Put the safety caps back on.
  9. 2004-2007 Chevrolet Malibu Headlight Replacement, Almost Done: 手順 9、 3の画像 1 2004-2007 Chevrolet Malibu Headlight Replacement, Almost Done: 手順 9、 3の画像 2 2004-2007 Chevrolet Malibu Headlight Replacement, Almost Done: 手順 9、 3の画像 3
    • Take your new bulb and place it back inside the headlight by twisting clockwise and making sure it doesn't come out or disconnect.
    • Reattach the headlight to the car with the 10 mm screws using a Phillips #0 screwdriver.
終わりに
To replace your headlight, follow these simple instructions.
作成者
1人の作成者と共同作成されました。
Nadia Simpson
メンバー登録日: 10/12/20
421 ポイント
2のガイドは作成済み
チーム
University of Memphis, Team 50-20, Willis Fall 2021 University of Memphis, Team 50-20, Willis Fall 2021人のメンバー
UM-WILLIS-F21S50G20
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 75
今までの合計 2,743
