メインコンテンツにスキップ
はじめに
Toyota Matrix 2003 automatic transmission speed sensor might be known as also: transaxle speed sensor, vehicle speed sensor (VSS). Thank you, vibeusa on Toyota Nation Forum, for sharing speed sensor location with diagram (2014-02-20 : Transmission VSS location?).
ツール
パーツ
パーツは指定されていません。
  1. Transaxle is behind and below engine.  You will have a hard time seeing it if your height is less than 170 cm.  If you are two metres tall or taller, then it will be easy to see. Some guides instruct to remove air filter, though I find that needless and not beneficial.
    • Transaxle is behind and below engine. You will have a hard time seeing it if your height is less than 170 cm. If you are two metres tall or taller, then it will be easy to see.
    • Some guides instruct to remove air filter, though I find that needless and not beneficial.
  2. Disconnect sensor now, or disconnect it later.  You might find it easier to unplug sensor after removing it from transaxle, when it is less far away from you, then easier to reach. Press on ridged tab to release clip/latch.  Grip connector, not wires, and pull it off of sensor.
    • Disconnect sensor now, or disconnect it later. You might find it easier to unplug sensor after removing it from transaxle, when it is less far away from you, then easier to reach.
    • Press on ridged tab to release clip/latch. Grip connector, not wires, and pull it off of sensor.
  3. Transaxle speed sensor is fastened down with one screw, 12mm hexagon head.  Use a socket on a long shaft to reach.  Just sixteen inches is long enough, also one half yard or half metre works. Observe the dimple in original screws which hold sensor together: these are JIS size 1 cruciform drive.  This observation is only meant to be interesting or informative, not relevant to guide. Observe the dimple in original screws which hold sensor together: these are JIS size 1 cruciform drive.  This observation is only meant to be interesting or informative, not relevant to guide.
    • Transaxle speed sensor is fastened down with one screw, 12mm hexagon head. Use a socket on a long shaft to reach. Just sixteen inches is long enough, also one half yard or half metre works.
    • Observe the dimple in original screws which hold sensor together: these are JIS size 1 cruciform drive. This observation is only meant to be interesting or informative, not relevant to guide.
終わりに
4 の人々がこのガイドを完成させました。
unsubstantiated
メンバー登録日: 2016年06月07日
976 ポイント
4のガイドは作成済み
3 件のコメント
Wire assignments in piece pictured: yellow is +12 volt, brown is 0 volt, green+white wire is output signal.
unsubstantiated - 返信
I have a 2003 toyota matrix xr awd and I looked where you told me too and unfortunately the speed sensor was not there. I also bought the manual for it that is for repairs and it showed the same location as of where you were showing and I am dealing with the same problem, no speed sensor.
Victoria West - 返信
Was easy to fix. Thanks
igbodike - 返信
コメントを追加
統計データを表示:
過去 24時間: 6
過去 7 日: 46
過去 30 日: 194
今までの合計 13,788
