メインコンテンツにスキップ
2003 Jeep Grand Cherokee Serpentine Belt Replacement
必要な工具と部品
  1. 2003 Jeep Grand Cherokee Serpentine Belt  Replacement, Serpentine Belt: 手順 1、 2の画像 1 2003 Jeep Grand Cherokee Serpentine Belt  Replacement, Serpentine Belt: 手順 1、 2の画像 2
    • Take a look at the belt routing diagram under the hood. If you didn't find it you can find a picture on the internet or draw one before beginning.
  2. 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 2、 3の画像 1 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 2、 3の画像 2 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 2、 3の画像 3
    • look carefully at how the old belt wraps around the pulleys, so you can replace the new one by practicing and matching the routing.
    • A/C Pulley
    • Tensioner
    • Idler Pulley
    • Crankshaft Pulley
    • Power Steering Pump Pulley
    • Generator Pulley
    • Water Pump Pulley
  3. 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 3、 3の画像 1 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 3、 3の画像 2 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 3、 3の画像 3
    • Now, use your 16 mm wrench to reduce the belt tension and get it off.
    • Put the socket wrench on the tensioner (Right your belt tensioner, the little square or cave).
    • Move the wrench clockwise to relieve tension from your belt tensioner.
  4. 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 4、 3の画像 1 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 4、 3の画像 2 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 4、 3の画像 3
    • Remove the old belt and make sure to put the new belt that doesn't have any cracks and looks smooth.
    • Before installing the new belt check the tensioner pulley for wear by using your hand to spin it.
  5. 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 5、 3の画像 1 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 5、 3の画像 2 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 5、 3の画像 3
    • Install the new belt by lining up all belt ribs in the pulley grooves and wrap it around.
    • Start with the A/C Pulley and then wrap it around the tensioner and move on until you end up with the water pump pulley.
    • When you ready to put the belt back on the alternator, reduce the tension on the belt by using the socket wrench and then slip the belt right over the top.
  6. 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 6、 2の画像 1 2003 Jeep Grand Cherokee Serpentine Belt  Replacement: 手順 6、 2の画像 2
    • Make sure at the end to tighten the tensioner and start your car to make sure it's work!
    • To adjust the tension, loosen the nut with a ratchet, so you can tighten the belt as required.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Balaqeel
メンバー登録日: 01/20/19
190 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 76
今までの合計 6,052
