メインコンテンツにスキップ
2003-2006 Chevrolet Silverado Headlight Bulb Replacement
必要な工具と部品
  1. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: 手順 1、 3の画像 1 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: 手順 1、 3の画像 2 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: 手順 1、 3の画像 3
    • Turn your vehicle off, and let the engine bay cool before starting the following steps.
    • First, open the driver side door, and reach under the steering wheel and release the latch to open up the hood of your truck.
    • Next, walk over to either of the headlights and remove the pin above the headlight to release the housing unit.
    • Make sure to put the pin in a safe location so you can lock in the housing once you finish replacing the light bulbs.
  2. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: 手順 2、 3の画像 1 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: 手順 2、 3の画像 2 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: 手順 2、 3の画像 3
    • Pinch the blue clips and remove them from the back of the wiring harness.
    • After removing the pin, you should now be able to tilt the headlight downward to gain access to all of the wires.
    • Twist the light bulb counter clockwise and gently remove the harness and the light bulb.
  3. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: 手順 3、 3の画像 1 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: 手順 3、 3の画像 2 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: 手順 3、 3の画像 3
    • Unbox your new low beam light, and insert it into the same hole you took the old one out of.
    • Be sure to twist the bulb clockwise until it locks into place with the harness pointing down.
    • Plug the blue wiring harness back in until you hear a click, and it should now be locked back into place.
  4. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: 手順 4、 3の画像 1 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: 手順 4、 3の画像 2 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: 手順 4、 3の画像 3
    • Begin to replace the headlight housing back into its original place by tucking in the wires.
    • Grab the pin that you took out at the beginning and insert it back into the housing unit.
    • Align the housing back with the guide holes for the pin.
  5. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Repeat: 手順 5、 2の画像 1 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Repeat: 手順 5、 2の画像 2
    • Follow steps 1-4 for the other headlight to replace the low beam headlight.
    • Make sure to keep track of all of your parts and dispose of your old bulbs properly.
    • Be sure to check your headlight alignment. This can be done by a professional or through Youtube videos.
終わりに
To replace the other light bulb just follow the same steps as above.
5 の人々がこのガイドを完成させました。
作成者
14人の作成者と共同で作成されました。
Alisson Silva
メンバー登録日: 09/11/15
197 ポイント
1ガイドが承認済み
チーム
Sam Houston State, Team 16-3, Nardone Fall 2015 Sam Houston State, Team 16-3, Nardone Fall 2015人のメンバー
SHSU-NARDONE-F15S16G3
4 メンバー
1のガイドは作成済み
コメント 1 件
FYI: don't touch the bulbs with bare hands. The oil from your fingers will cause them to burn out early.
Jay Wilhoite - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 19
過去 30 日: 82
今までの合計 40,853
