メインコンテンツにスキップ
はじめに
This is a guide on how to replace the low beam lights on a 2004 Chevrolet Silverado. The headlight is held in place by clips. You will not needs any tools to complete this project beside the replacement bulbs. Having a rag or terry cloth is best for handling the bulb.
ツール
ツールは指定されていません。
  1. Turn your vehicle off, and let the engine bay cool before starting the following steps. First, open the driver side door, and reach under the steering wheel and release the latch to open up the hood of your truck. Next, walk over to either of the headlights and remove the pin above the headlight to release the housing unit.
    • Turn your vehicle off, and let the engine bay cool before starting the following steps.
    • First, open the driver side door, and reach under the steering wheel and release the latch to open up the hood of your truck.
    • Next, walk over to either of the headlights and remove the pin above the headlight to release the housing unit.
    • Make sure to put the pin in a safe location so you can lock in the housing once you finish replacing the light bulbs.
  2. Pinch the blue clips and remove them from the back of the wiring harness. After removing the pin, you should now be able to tilt the headlight downward to gain access to all of the wires. Twist the light bulb counter clockwise and gently remove the harness and the light bulb.
    • Pinch the blue clips and remove them from the back of the wiring harness.
    • After removing the pin, you should now be able to tilt the headlight downward to gain access to all of the wires.
    • Twist the light bulb counter clockwise and gently remove the harness and the light bulb.
  3. Unbox your new low beam light, and insert it into the same hole you took the old one out of. Be sure to twist the bulb clockwise until it locks into place with the harness pointing down. Plug the blue wiring harness back in until you hear a click, and it should now be locked back into place.
    • Unbox your new low beam light, and insert it into the same hole you took the old one out of.
    • Be sure to twist the bulb clockwise until it locks into place with the harness pointing down.
    • Plug the blue wiring harness back in until you hear a click, and it should now be locked back into place.
  4. Begin to replace the headlight housing back into its original place by tucking in the wires. Grab the pin that you took out at the beginning and insert it back into the housing unit. Align the housing back with the guide holes for the pin.
    • Begin to replace the headlight housing back into its original place by tucking in the wires.
    • Grab the pin that you took out at the beginning and insert it back into the housing unit.
    • Align the housing back with the guide holes for the pin.
  5. Follow steps 1-4 for the other headlight to replace the low beam headlight. Make sure to keep track of all of your parts and dispose of your old bulbs properly.
    • Follow steps 1-4 for the other headlight to replace the low beam headlight.
    • Make sure to keep track of all of your parts and dispose of your old bulbs properly.
    • Be sure to check your headlight alignment. This can be done by a professional or through Youtube videos.
終わりに
To replace the other light bulb just follow the same steps as above.
3 の人々がこのガイドを完成させました。
Alisson Silva
メンバー登録日: 2015年09月11日
167 ポイント
1ガイドが承認済み
チーム
Sam Houston State, Team 16-3, Nardone Fall 2015 Sam Houston State, Team 16-3, Nardone Fall 2015人のメンバー
SHSU-NARDONE-F15S16G3
4 メンバー
1のガイドは作成済み
コメント1件
FYI: don't touch the bulbs with bare hands. The oil from your fingers will cause them to burn out early.
Jay Wilhoite - 返信
コメントを追加
統計データを表示:
過去 24時間: 4
過去 7 日: 36
過去 30 日: 183
今までの合計 38,301
