メインコンテンツにスキップ
2003-2007 Honda Accord Spark Plugs Replacement
必要な工具と部品
  1. 2003-2007 Honda Accord Spark Plugs Replacement, Opening the Hood: 手順 1、 2の画像 1 2003-2007 Honda Accord Spark Plugs Replacement, Opening the Hood: 手順 1、 2の画像 2
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
  2. 2003-2007 Honda Accord Spark Plugs Replacement: 手順 2、 2の画像 1 2003-2007 Honda Accord Spark Plugs Replacement: 手順 2、 2の画像 2
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  3. 2003-2007 Honda Accord Spark Plugs Replacement: 手順 3、 2の画像 1 2003-2007 Honda Accord Spark Plugs Replacement: 手順 3、 2の画像 2
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
  4. 2003-2007 Honda Accord Spark Plugs Replacement, Spark Plugs: 手順 4、 2の画像 1 2003-2007 Honda Accord Spark Plugs Replacement, Spark Plugs: 手順 4、 2の画像 2
    • Use a 10 mm hex driver or socket to remove the four screws that hold the spark plug cover in place.
    • Lift the plastic cover and set it aside.
  5. 2003-2007 Honda Accord Spark Plugs Replacement: 手順 5、 3の画像 1 2003-2007 Honda Accord Spark Plugs Replacement: 手順 5、 3の画像 2 2003-2007 Honda Accord Spark Plugs Replacement: 手順 5、 3の画像 3
    • Remove the spark plug wire by pinching the locking tabs on either side of it and pulling it out.
  6. 2003-2007 Honda Accord Spark Plugs Replacement: 手順 6、 2の画像 1 2003-2007 Honda Accord Spark Plugs Replacement: 手順 6、 2の画像 2
    • Use a 10 mm hex driver or socket to remove the four spark plug boot screws.
  7. 2003-2007 Honda Accord Spark Plugs Replacement: 手順 7、 3の画像 1 2003-2007 Honda Accord Spark Plugs Replacement: 手順 7、 3の画像 2 2003-2007 Honda Accord Spark Plugs Replacement: 手順 7、 3の画像 3
    • Lift the boot screws out of the spark plug bores.
  8. 2003-2007 Honda Accord Spark Plugs Replacement: 手順 8、 2の画像 1 2003-2007 Honda Accord Spark Plugs Replacement: 手順 8、 2の画像 2
    • Locate the spark plug at the bottom of the bore.
    • Use a ratchet, extension, and 5/8 inch socket to remove the plug by turning counterclockwise until it's free.
  9. 2003-2007 Honda Accord Spark Plugs Replacement: 手順 9、 3の画像 1 2003-2007 Honda Accord Spark Plugs Replacement: 手順 9、 3の画像 2 2003-2007 Honda Accord Spark Plugs Replacement: 手順 9、 3の画像 3
    • Pull the plug out of the bore.
  10. 2003-2007 Honda Accord Spark Plugs Replacement: 手順 10、 1の画像 1
    • Determine if the spark plug needs to be replaced by examining the gap for the problems listed below:
    • The gap is bridged by corrosion.
    • The gap is too large.
    • The area around the gap is black and dark.
  11. 2003-2007 Honda Accord Spark Plugs Replacement: 手順 11、 1の画像 1
    • If the spark plug doesn't need to be replaced, return it to the spark plug bore. If it does need to be replaced, use a new one.
    • Use of Anti-Seize on the thread of spark plug is highly recommended to ensure threads don't get damaged while tightening.
    • Use a ratchet, extension, and 5/8 inch socket to tighten the spark plug by turning clockwise. Use your hand to tighten as well.
    • If a torque wrench is available, tighten to 13 ft-lbs.
    • Repeat Steps 10-13 for the three remaining spark plugs.
終わりに
After reinstalling all four spark plugs, follow Steps 3-9 in reverse order to reattach the spark plug cover and close the car's hood.
36 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Shaun MacDonald
メンバー登録日: 10/03/12
2,558 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 24-27, Regan Fall 2012 Cal Poly, Team 24-27, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S24G27
4 メンバー
22のガイドは作成済み
7 件のコメント
Great instructions! I was able to change them pretty quickly.
JOEL DENNIS - 返信
First rule of thumb when changing spark plugs is to do it when the engine is cold. If you don't have a torque wrench it's ok, you can still tighten them properly. Easiest thing to do is put the new plug in the spark plug socket, attach the extension (8 or 10 in. is perfect) but not the ratchet. Thread the plug in until it is snug, then attach the ratchet to tighten. Most spark plug manufacturers put on the box (especially NGK) how much to tighten. Usually if the plug has no gasket, tighten 1/16 to 1/8 of a turn. If it has a gasket, tighten 1/2 to 2/3 of a turn. For an '05 Accord 4 cyl. they have a gasket.
wingmaneh - 返信
Thanks for the clear instructions & photos!
Steve T - 返信
I appreciate the thorough and precise instructions. I would add using anti-seize on new plug threads.
ssnider727 - 返信
On an '05 Accord, are there any wires that need to be replaced at a regular interval?
Ryan Roux - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 79
過去 30 日: 421
今までの合計 100,634
