はじめに
Welcome to this no nonsense easy and quick replacement of the side mirror of a 2003-2007 7th Generation Honda Accord. This guide will be a simple 6 steps, that will be fairly easy to follow. You may be wondering, how many tools you will be needing to complete the task. The only tool needed, is a socket wrench and a 8mm socket head header bolt, to just unscrew 3 easy bolts. This guide no prior knowledge is needed, only that if you know how to use a socket wrench. The reason for this guide is many unfortunate events can happen to your car at any given moment, so this guide is to help replace the mirror in the case it as ever damaged. The repair is easy and fast. The only caution about this guide is to not loose the bolts when unscrewing them.
必要な工具と部品
ある他の人がこのガイドを完成しました。
