はじめに
Headlights are an integral component to safety on the road for both yourself and other drivers . Knowing how to replace your headlight can save you money, time and maintain your safety in the case that your headlight breaks.
Identify the hood release button within your vehicle. For 2003 models, this button is located underneath the driver's wheel, near the hinge of the door.
Once located, activate the hood release by pressing the button - you should hear a slight click noise as the hood pops up slightly.
Lift up the hood.
Identify the hood support rod. For the 2003 model, and most all cars, it will be located directly to the left of the engine compartment.
Place the hood support rod into the support rod hole within the hood itself. This will be located just to the left of the center of the hood.
ある他の人がこのガイドを完成しました。
