2003-2007 Honda Accord Front Brake Pads Replacement
はじめに
Brake pad life varies greatly by driving style and car use. There is no specific mile count at which brake pads should be changed. The best indicator of worn brake pads is a screeching sound when braking. It is recommended that you change your brake pads when this occurs.
Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
Identify the two mounting bolts on the rear of the caliper.
Using a 12 mm wrench or socket, remove the two caliper mounting bolts.
Alternatively, you may remove only the bottom mounting bolt and, using the top bolt as a hinge, rotate the caliper up and away from the rotor to access the brake pads. If you do this, skip the next step.
Inspect the brake pad wear sensor on the old brake pad. The sensor is a metallic tab attached to the brake pad. When the brake pads wear down too much, the metallic tab contacts the rotor and makes a screeching sound.
The new brake pads are thicker than the old pads. Because of this, the caliper piston protrudes too far out to allow enough clearance for the caliper to be placed over the new pads. You will need to manually retract the caliper piston.
To do this, place an old brake pad over the caliper piston.
Place one end of the c-clamp jaw over the old pad. Place the other end of the jaw on the rear of the caliper. Tighten the c-clamp to push the piston back into the caliper.
This will push oil back into the brake reservoir, which could overflow. This can be wasteful, messy, and damage your car's paint job. Make sure the reservoir isn't topped off. It is also a good idea to remove the cap from the reservoir before retracting the piston. The reservoir is located under the hood and should be clearly labeled.
Slide the caliper over the brake pad bracket with the new brake pads.
If you removed the cap from the brake fluid reservoir replace it as soon as the brake caliper piston has been retracted. Do not leave the cap off any longer than absolutely necessary.
To reassemble the wheel assembly. Follow the Steps 1-7 in reverse order.
The caliper mounting bolts and the lug nuts must be tightened to the correct torque value, using a torque wrench. The values may differ depending on your car's configuration and options, but are typically listed as:
Caliper bolts: 54 ft lbs
Lug nuts: 80 ft lbs
Remove the jack stand. Then lower and remove the floor jack.
CAUTION! : Before driving the car, pump the brake pedal several times in order to push the caliper piston back against the brake pads. If this step is not performed, the car may not brake reliably when first driven. For your safety, this step is essential.
Safety tip - before lifting the car up with the jack, break loss the lug nuts as in step 5, break lose means to get them started but they are still snug. Why - This way you don't have to crank with strength when the car is on the stands and possibly knock it off the stands.
