メインコンテンツにスキップ
2003-2007 Honda Accord Cabin Air Filter Replacement
必要な工具と部品
  1. 2003-2007 Honda Accord Cabin Air Filter Replacement, Cabin Air Filter: 手順 1、 2の画像 1 2003-2007 Honda Accord Cabin Air Filter Replacement, Cabin Air Filter: 手順 1、 2の画像 2
    • Open the passenger side door and locate the glove box. Open and empty the glove box.
  2. 2003-2007 Honda Accord Cabin Air Filter Replacement: 手順 2、 1の画像 1
    • Identify the glove box damper assy latch on the right side of the glove box. Using moderate force, press against the latch with your thumb until it pops out of place.
  3. 2003-2007 Honda Accord Cabin Air Filter Replacement: 手順 3、 1の画像 1
    • The glove box is held in place by tabs on both sides. Push inward on both sides of the box to allow the glove box to drop clear the tabs and drop downward slowly.
  4. 2003-2007 Honda Accord Cabin Air Filter Replacement: 手順 4、 3の画像 1 2003-2007 Honda Accord Cabin Air Filter Replacement: 手順 4、 3の画像 2 2003-2007 Honda Accord Cabin Air Filter Replacement: 手順 4、 3の画像 3
    • Now that the cabin air filter housing is visible locate the locking tabs on the left and right edges.
    • Push the tabs inward and gently shake the housing free while pulling straight out.
    • When reassembling, push the filter tray in gently until both locking tabs click into position. The filter must be inserted into the tray fully for the tray to fit back in.
  5. 2003-2007 Honda Accord Cabin Air Filter Replacement: 手順 5、 1の画像 1
    • Push the air filter out of the plastic housing from the bottom and discard.
  6. 2003-2007 Honda Accord Cabin Air Filter Replacement: 手順 6、 2の画像 1 2003-2007 Honda Accord Cabin Air Filter Replacement: 手順 6、 2の画像 2
    • Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy.
    • Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
    • Ensure that the last vanes on the front and back of the filter fit into the retaining tabs in the filter tray to prevent any particulates passing around the filter.
    This was very helpful thanks
    William Rosser - 返信
終わりに
21 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Shaun MacDonald
メンバー登録日: 10/03/12
2,558 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 24-27, Regan Fall 2012 Cal Poly, Team 24-27, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S24G27
4 メンバー
22のガイドは作成済み
コメント 1 件
Good easy to understand directions and removal of cabin air filter . Thank You
raysanchez120 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 77
今までの合計 31,522
