はじめに
It is suggested that you change your engine oil and filter every 5000 miles.
必要な工具と部品
Locate the hood latch beside the driver's side door, next to the left foot rest.
Pull the latch toward you to release the hood.
Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
Remove the dipstick by lifting vertically.
Wipe all the oil off of the dipstick and put it back into the dipstick port.
Let the oil completely drain into the drip pan.
Put a new crush washer on the drain bolt, then reinstall the drain bolt.
Using a torque wrench, tighten it to:
33 lbf·ft (45 N·m , 4.6 kgf·m) for 4-cylinder models
or 29 lbf·ft (39 N·m , 4.0 kgf·m) for 6-cylinder models.
Set the drip pan aside.
28 の人々がこのガイドを完成させました。
25 件のコメント
You should do it while the engine is hot so the oil drains faster. Removing the the fill cap should be done before removing the drain plug. That will also help the oil drain faster and more completely. And 5 quarts is too much for that engine. It's more like 4.4 or 4.5 quarts. Over filling it is really bad. The counterweights on the crankshaft will splash in the oil creating a froth with air bubbles in it causing the oil to not lubricate the engine well which will wear out the engine faster
Yeah. What he said. Well maybe not a hot engine... But certainly not a cold one.
codeh d -
Can u pls help me for my accord problem
I just recently change my oil last 3 months and now the dipstick is showing no oil I had use castrol edge 5w-40 fully synthetic oil and now there is no oil can u pls help me
Don't change oil when really hot. You WILL burn yourself.
