メインコンテンツにスキップ
2002-2006 Toyota Camry Windshield Wiper Replacement
必要な工具と部品
  1. 2002-2006 Toyota Camry Windshield Wiper Replacement, Windshield Wiper: 手順 1、 2の画像 1 2002-2006 Toyota Camry Windshield Wiper Replacement, Windshield Wiper: 手順 1、 2の画像 2
    • Lift windshield wiper arms off the windshield and into the air.
  2. 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 2、 2の画像 1 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 2、 2の画像 2
    • Place your thumb and index finger on each side of the small central mechanism.
    • Gently squeeze the small mechanism together with your thumb and index finger and push the mechanism up.
  3. 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 3、 3の画像 1 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 3、 3の画像 2 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 3、 3の画像 3
    • Carefully, but firmly, pull windshield wiper blades down towards the hood of the car to “unhook” the blade from the wiper arm.
    • Place your towel on the windshield to protect it in case the arm drops onto the windshield.
  4. 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 4、 2の画像 1 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 4、 2の画像 2
    • On the driver's side, push the 24" wiper blade up towards the sky and into the hooks on the windshield wiper arm. The new blade should firmly click into place.
    • Repeat on the passenger's side using the 19" wiper blade.
  5. 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 5、 3の画像 1 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 5、 3の画像 2 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 5、 3の画像 3
    • Remove towels or other padding from windshield.
  6. 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 6、 3の画像 1 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 6、 3の画像 2 2002-2006 Toyota Camry Windshield Wiper Replacement: 手順 6、 3の画像 3
    • Give both windshield wiper arms a gentle, but firm, shake to confirm that the new wiper blades are secure.
    • Carefully put the passenger's side wiper arm back onto the windshield first. Then put the driver's side wiper arm down on the windshield.
終わりに
Congratulations, you have properly replaced your windshield wipers!
作成者
2人の作成者と共同で作成されました。
Lucas Labrador
メンバー登録日: 10/18/23
133 ポイント
1ガイドが承認済み
チーム
Sam Houston State, Team 2-3, Bennett Fall 2023 Sam Houston State, Team 2-3, Bennett Fall 2023人のメンバー
SHSU-BENNETT-F23S2G3
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 37
今までの合計 331
