メインコンテンツにスキップ
2002-2006 Acura Integra Windshield Wipers Replacement
必要な工具と部品
  1. 2002-2006 Acura Integra Windshield Wipers Replacement, Windshield Wiper: 手順 1、 3の画像 1 2002-2006 Acura Integra Windshield Wipers Replacement, Windshield Wiper: 手順 1、 3の画像 2 2002-2006 Acura Integra Windshield Wipers Replacement, Windshield Wiper: 手順 1、 3の画像 3
    • Use the tape measure to measure the length of the wiper blades from top to bottom.
    • This will help you determine the correct size of replacement wipers that you will need.
  2. 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 2、 3の画像 1 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 2、 3の画像 2 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 2、 3の画像 3
    • Lift the windshield wiper off the windshield.
    • Place a towel underneath the wiper to prevent damage to the windshield if the wiper is dropped.
    • Avoid lifting the windshield wiper too far back; doing so can cause damage to what helps the wiper stay against the windshield.
  3. 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 3、 3の画像 1 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 3、 3の画像 2 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 3、 3の画像 3
    • Lift open the clip above the wiper with one hand while holding the wiper arm up with the other.
    • Opening this clip will allow us to slide the wiper off for the next step.
  4. 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 4、 2の画像 1 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 4、 2の画像 2
    • Grab the wiper with one hand while holding the wiper arm up with the other.
    • Slide the wiper down.
    • Once unhooked, pull the wiper back and away from the wiper arm to remove the wiper.
  5. 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 5、 2の画像 1 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 5、 2の画像 2
    • Place the replacement wiper against the wiper arm with the hooking mechanism facing the hook of the wiper arm.
    • Slide the wiper up, thus putting it into place.
  6. 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 6、 3の画像 1 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 6、 3の画像 2 2002-2006 Acura Integra Windshield Wipers Replacement: 手順 6、 3の画像 3
    • Once the wiper is slid up all the way, grab the top clip of the wiper.
    • Close the clip until a click is heard.
    • Remove the towel and lower the wiper arm down gently.
終わりに
Follow these instructions for the second windshield wiper.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Brian Gonzalez
メンバー登録日: 12/05/22
154 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 3-11, Briggs Fall 2022 CSU Los Angeles, Team 3-11, Briggs Fall 2022人のメンバー
CSULA-BRIGGS-F22S3G11
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 4
今までの合計 108
