はじめに
This guide will demonstrate how to do a routine maintenance differential oil change to your 2002-2008 Dodge Ram 1500 Chrysler LSD. Due to limited resources the differential oil was not actually changed in this guide.
必要な工具と部品
Locate the twelve 10mm long 14mm hex head bolts holding on the backplate of the differential.
Position an oil pan under the differential.
Loosen the bottom 4 bolts first with the 14mm socket wrench. Slowly loosen the rest of the bolts in a random order until oil flows out and enters the drain pan.
Locate the differential filler plug.
Use a #2 flathead screwdriver to lift the outer lip of the plug. Pinch the outer lip of the rubber filler plug between your fingers and pull off.
Use a vacuum pump to pump in new differential fluid until the oil level reaches the bottom of the plug hole.
Re-insert the rubber filler plug.
5 の人々がこのガイドを完成させました。
2 件のコメント
Don’t forget the clean the old gasket material off, wipe up any differential fluid residue, clean the mating surface with brake cleaner, and add a new gasket maker material.
This guide really left out some very important steps. And don’t reuse your diff fluid people.
No mention of anti-slip additive which is not optional.
