メインコンテンツにスキップ
2002-2009 Kia Sorento Outer Door Handle Replacement
必要な工具と部品
  1. 2002-2009 Kia Sorento Outer Door Handle Replacement, Outer Door Handle: 手順 1、 3の画像 1 2002-2009 Kia Sorento Outer Door Handle Replacement, Outer Door Handle: 手順 1、 3の画像 2 2002-2009 Kia Sorento Outer Door Handle Replacement, Outer Door Handle: 手順 1、 3の画像 3
    • Some of the screws are hidden under plastic screw covers or panels which have to be carefully pried off. Use a spudger or opening tool if possible to remove the screw covers.
    • Use a Phillips #1 screwdriver to remove the screws behind the covers.
  2. 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 2、 2の画像 1 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 2、 2の画像 2
    • Use a Phillips #3 screwdriver to remove the plastic fasteners by the left side of the door.
    • To remove the plastic fasteners we found that applying a little bit of pressure with the flat head tool while unscrewing made the process easier.
  3. 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 3、 2の画像 1 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 3、 2の画像 2
    • Use the door panel removal tool to pry starting from the bottom of the door panel and moving from right to left.
    • In the second image you can see the yellow plastic clips which keep the door in place.
  4. 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 4、 2の画像 1 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 4、 2の画像 2
    • To remove the door panel you need to detach the light bulb of the interior door light on the bottom right of the door panel.
    • Detach the bulb by twisting clockwise and pulling the black base.
    • Beware the bulb is quite hot to the touch if turned on.
  5. 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 5、 2の画像 1 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 5、 2の画像 2
    • Peel off the upper right corner of the plastic covering to reveal the inside of the outer door handle.
    • One of the 10 mm hex nuts is revealed immediately (highlighted with the red circle) but the second 10 mm hex nut is behind a plastic tape which must be removed to access it (highlighted by red arrow).
    • To loosen the nuts use the 10 mm socket and ratchet with an extension.
  6. 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 6、 3の画像 1 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 6、 3の画像 2 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 6、 3の画像 3
    • To access the bolt at the side of the door use a prying tool to remove the plastic covering.
    • Use the 10 mm socket and drive ratchet to unfasten the 10 mm hex bolt.
    • This will leave the handle unmounted from the door.
  7. 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 7、 3の画像 1 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 7、 3の画像 2 2002-2009 Kia Sorento Outer Door Handle Replacement: 手順 7、 3の画像 3
    • Now that the door handle is no longer resting in the door there is a white plastic clamp that hugs a metal bar.
    • Release the outer door handle by pushing the white plastic clamp the direction the red arrow is pointing in the second image.
    • Once the door handle is off the door carefully pull the lock cylinder.
終わりに
To reassemble the door follow the step in reverse order.
作成者
1人の作成者と共同作成されました。
José A Colón Caldera
メンバー登録日: 03/18/22
145 ポイント
1ガイドが承認済み
チーム
4 件のコメント
I am just wondering my daughter has the 2006 Kia Portage 16 valve now her handle broke off but it's not actually the handle it's the metal part that it hooks to what is it called
Jason Gerbrandt - 返信
Sorry it was a Kia Sportage 16 valve and I just don't know what part to order the little metal rod that the handle hooks to snap what part do I need to order to fix it
I was told it was the actuator but when I looked on Amazon I didn't see the plastic housing that it would hook to I'm hoping a mechanic can let me know I am a tradesman myself just not a mechanic and we need some guidance
If it makes it easier I would give you my personal number so we can text personally
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 25
過去 30 日: 79
今までの合計 3,166
