メインコンテンツにスキップ
2001 Chevrolet Suburban Rear Window Struts Replacement
必要な工具と部品
  1. 2001 Chevrolet Suburban Rear Window Struts Replacement, Rear Window Struts: 手順 1、 2の画像 1 2001 Chevrolet Suburban Rear Window Struts Replacement, Rear Window Struts: 手順 1、 2の画像 2
    • Open the window.
    • Support the window with either a partner's hands or a sturdy prop.
    • A prop is used in the photos.
  2. 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 2、 2の画像 1 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 2、 2の画像 2
    • Position the small screwdriver on the indentation in the lower joint of the strut.
    • Gently wedge the screwdriver under the metal locking tab and pop it out.
    • You don't have to completely remove the tab—just make sure it doesn't pop back into place. Getting a screwdriver completely under it (as shown) is usually enough.
    • If needed, use the larger screwdriver to help loosen the tab.
  3. 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 3、 2の画像 1 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 3、 2の画像 2
    • Position the screwdriver on the indentation in the upper joint.
  4. 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 4、 2の画像 1 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 4、 2の画像 2
    • Stand at the back of the vehicle (behind the rear bumper) and face the lower joint of the strut.
    • Grab the lower joint.
    • Pull firmly, straight towards you and slightly upwards until the joint pops off.
  5. 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 5、 2の画像 1 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 5、 2の画像 2
    • Stand at the side of the vehicle and face the upper joint of the strut.
    • Grab the upper joint.
    • Pull firmly, straight towards you until the joint pops off. Do not pull upwards or downwards.
  6. 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 6、 2の画像 1 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 6、 2の画像 2
    • Remove the new strut from its packaging.
    • Align the socket of the upper joint with the mounting stud.
    • The upper joint is on the end with the thick black plastic.
    • Firmly press the joint until it snaps on.
  7. 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 7、 2の画像 1 2001 Chevrolet Suburban Rear Window Struts Replacement: 手順 7、 2の画像 2
    • Align the socket of the bottom joint with the mounting stud.
    • The bottom joint is on the end with the bare metal rod.
終わりに
Repeat this process for the other strut. That’s it!
作成者
1人の作成者と共同作成されました。
Alex Dierks
メンバー登録日: 02/19/21
145 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G23, Raign Spring 2021 University of North Texas, Team S1-G23, Raign Spring 2021人のメンバー
UNT-RAIGN-S21S1G23
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 20
今までの合計 583
