メインコンテンツにスキップ
2001-2006 Toyota Tundra Tailgate Replacement
必要な工具と部品
  1. 2001-2006 Toyota Tundra Tailgate Replacement, Tailgate: 手順 1、 3の画像 1 2001-2006 Toyota Tundra Tailgate Replacement, Tailgate: 手順 1、 3の画像 2 2001-2006 Toyota Tundra Tailgate Replacement, Tailgate: 手順 1、 3の画像 3
    • Use a Torx T30 screwdriver to remove the eight 27.0 mm screws on the inside of the tailgate securing the bed-liner panel to the tailgate.
  2. 2001-2006 Toyota Tundra Tailgate Replacement: 手順 2、 2の画像 1 2001-2006 Toyota Tundra Tailgate Replacement: 手順 2、 2の画像 2
    • With the screws removed, lift and remove the bed-liner panel on the inside of the tailgate.
    • Do not touch the top of the tailgate. It's made from fiberglass that could cause splinters due to age or deterioration.
  3. 2001-2006 Toyota Tundra Tailgate Replacement: 手順 3、 3の画像 1 2001-2006 Toyota Tundra Tailgate Replacement: 手順 3、 3の画像 2 2001-2006 Toyota Tundra Tailgate Replacement: 手順 3、 3の画像 3
    • Remove the metal panel beneath the bed-liner panel.
    • The metal panel uses the same screws as the bed-liner panel and can be removed at the same time.
  4. 2001-2006 Toyota Tundra Tailgate Replacement: 手順 4、 3の画像 1 2001-2006 Toyota Tundra Tailgate Replacement: 手順 4、 3の画像 2 2001-2006 Toyota Tundra Tailgate Replacement: 手順 4、 3の画像 3
    • Grasp the cables and push inwards with both hands until the tailgate is released from the truck bed.
  5. 2001-2006 Toyota Tundra Tailgate Replacement: 手順 5、 3の画像 1 2001-2006 Toyota Tundra Tailgate Replacement: 手順 5、 3の画像 2 2001-2006 Toyota Tundra Tailgate Replacement: 手順 5、 3の画像 3
    • Open the tailgate until it is flat or parallel with the ground.
  6. 2001-2006 Toyota Tundra Tailgate Replacement: 手順 6、 3の画像 1 2001-2006 Toyota Tundra Tailgate Replacement: 手順 6、 3の画像 2 2001-2006 Toyota Tundra Tailgate Replacement: 手順 6、 3の画像 3
    • Remove the cables that connect the tailgate to the truck bed by prying the metal tab towards you using the flat head bit on the screwdriver.
    • Pry the tab up until the cable can be removed from the tailgate cable bolt.
    • The tailgate may need to be lifted up slightly to remove the cable from the tailgate cable bolt.
    • Repeat for both sides of the tailgate.
  7. 2001-2006 Toyota Tundra Tailgate Replacement: 手順 7、 2の画像 1 2001-2006 Toyota Tundra Tailgate Replacement: 手順 7、 2の画像 2
    • Lift the tailgate until it forms a 45° angle with the horizontal.
  8. 2001-2006 Toyota Tundra Tailgate Replacement: 手順 8、 3の画像 1 2001-2006 Toyota Tundra Tailgate Replacement: 手順 8、 3の画像 2 2001-2006 Toyota Tundra Tailgate Replacement: 手順 8、 3の画像 3
    • Detach the right side of the tailgate by lifting it away from the truck at a 45° angle.
  9. 2001-2006 Toyota Tundra Tailgate Replacement: 手順 9、 3の画像 1 2001-2006 Toyota Tundra Tailgate Replacement: 手順 9、 3の画像 2 2001-2006 Toyota Tundra Tailgate Replacement: 手順 9、 3の画像 3
    • Pull the left side of the tailgate away from the left side of the truck to detach it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Matt Pires
メンバー登録日: 04/19/23
181 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 2-7, Morris Spring 2023 UC Davis, Team 2-7, Morris Spring 2023人のメンバー
UCD-MORRIS-S23S2G7
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 42
過去 30 日: 144
今までの合計 1,241
