メインコンテンツにスキップ
2001-2006 Mini Cooper Radio Replacement
必要な工具と部品
  1. 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: 手順 1、 3の画像 1 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: 手順 1、 3の画像 2 2001-2006 Mini Cooper Radio Replacement, Radio / Head Unit: 手順 1、 3の画像 3
    • Grab the knee bolster panel under the steering column with both hands.
    • Pull it down and out.
    • Using a Torx screwdriver with T30 tip, remove the two M5 x 2.5 x 25 screws in the left pillar.
  2. 2001-2006 Mini Cooper Radio Replacement: 手順 2、 3の画像 1 2001-2006 Mini Cooper Radio Replacement: 手順 2、 3の画像 2 2001-2006 Mini Cooper Radio Replacement: 手順 2、 3の画像 3
    • Open the glovebox.
    • Using a Torx screwdriver with a T20 tip, remove the two M5 x 2.5 x 30 screws in the right hand side pillar.
    • Minis in America will usually have a cup holder attached with these 2 screws on the right. It will come off when the 2 screws are removed and can be set to the side.
  3. 2001-2006 Mini Cooper Radio Replacement: 手順 3、 3の画像 1 2001-2006 Mini Cooper Radio Replacement: 手順 3、 3の画像 2 2001-2006 Mini Cooper Radio Replacement: 手順 3、 3の画像 3
    • With the glovebox still open, grab the bottom of the passenger dash panel and pull it forward. The panel does not need to be removed, just popped out.
    • Grab under the driver side dash panel near the radio and pull it forward. Again, the panel does not need to be removed, just popped out.
    • Pull each side of the middle dash panel until it pops out, like the previous ones.
  4. 2001-2006 Mini Cooper Radio Replacement: 手順 4、 3の画像 1 2001-2006 Mini Cooper Radio Replacement: 手順 4、 3の画像 2 2001-2006 Mini Cooper Radio Replacement: 手順 4、 3の画像 3
    • Grab the left hand side pillar, then pull it out and to the left.
    • Grab the right hand side pillar, then pull it out and to the right.
    • The four screws holding the radio in should now be exposed.
  5. 2001-2006 Mini Cooper Radio Replacement: 手順 5、 3の画像 1 2001-2006 Mini Cooper Radio Replacement: 手順 5、 3の画像 2 2001-2006 Mini Cooper Radio Replacement: 手順 5、 3の画像 3
    • Using a screwdriver with a T20 bit, take out the four M3 x 2 x 20 screws holding the radio in place.
    • Some models have philips head screws instead of the regular torx head depending on age.
  6. 2001-2006 Mini Cooper Radio Replacement: 手順 6、 2の画像 1 2001-2006 Mini Cooper Radio Replacement: 手順 6、 2の画像 2
    • Grab the radio and gently pull it out of the dash.
  7. 2001-2006 Mini Cooper Radio Replacement: 手順 7、 3の画像 1 2001-2006 Mini Cooper Radio Replacement: 手順 7、 3の画像 2 2001-2006 Mini Cooper Radio Replacement: 手順 7、 3の画像 3
    • Pinch the antenna connector and pull it straight out.
  8. 2001-2006 Mini Cooper Radio Replacement: 手順 8、 2の画像 1 2001-2006 Mini Cooper Radio Replacement: 手順 8、 2の画像 2
    • For the main connector, pinch the lever arm with the piece of plastic next to it.
    • Lift up on the arm and pull the connector out.
    • The radio can now be removed from the car.
終わりに
8 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
David Olson
メンバー登録日: 03/24/20
373 ポイント
1ガイドが承認済み
チーム
Purdue University Northwest, Team S6-G42, Hingst Spring 2020 Purdue University Northwest, Team S6-G42, Hingst Spring 2020人のメンバー
PNW-HINGST-S20S6G42
1 メンバー
1のガイドは作成済み
2 件のコメント
I bought everything to install a aftermarket radio in my 2005. Mini s. Everything lights up. Stations tune in but no sound
Roy Ober - 返信
The replacement radio powers on but there's no audio. Which wire provides power to the amp for audio? It seems like I've tried them all....
Olu - 返信
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 78
過去 30 日: 308
今までの合計 14,449
