はじめに
Replacing your own air filter is both easy and cost effective. By following this guide you can have a new filter installed in as little as 10 minutes.
ツール
工具は必要ありません。
パーツ
  1. Locate the air filter housing unit below the glove box. Open housing unit to reach air filter by locating the three clips, one on the rear of the box and the two on the front. Open the rear clip first by applying an outward and downward force. Repeat process for the front clips.
    • Locate the air filter housing unit below the glove box.
    • Open housing unit to reach air filter by locating the three clips, one on the rear of the box and the two on the front.
    • Open the rear clip first by applying an outward and downward force. Repeat process for the front clips.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Filter lays in a pair of guide rails for easy removal and replacement. Pinch base of filter with thumb.
    • Filter lays in a pair of guide rails for easy removal and replacement.
    • Pinch base of filter with thumb.
    • Once the filter is pinched it can easily be pulled out by the guide rails with moderate force.
  4. Replace the old filter with the new filter.
    • Replace the old filter with the new filter.
    • Reassemble the air filter by following the guide in reverse. On the side of the filter, there should be writing telling which direction the air flow goes in for putting it back in right way up. The air should be flowing into the foot well so you want the arrows pointing down.
ゴール
3 の人々がこのガイドを完成させました。
Eli
メンバー登録日: 2013年10月10日
265 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 8-19, Regan Fall 2013 Cal Poly, Team 8-19, Regan Fall 2013人のメンバー
CPSU-REGAN-F13S8G19
3 メンバー
4のガイドは作成済み
コメント1件
thank you for your page…you made it easy to understand…and the pics were great also!
Debbie Ross - 返信
統計データを表示:
過去 24時間: 6
過去 7 日: 16
過去 30 日: 65
今までの合計 3,430
