メインコンテンツにスキップ
2000 Gmc Sierra Light Replacement
必要な工具と部品
  1. 2000 Gmc Sierra Light Replacement, Headlights, Taillights, and an overhead light: 手順 1、 1の画像 1
    • Open your tailgate fully, exposing both sides where the tailgate sits.
  2. 2000 Gmc Sierra Light Replacement: 手順 2、 1の画像 1
    • Unscrew the two phillips head screws located above and below the tailgate support.
  3. 2000 Gmc Sierra Light Replacement: 手順 3、 1の画像 1
    • Once the screws have been removed, simply pull off the taillight. The red plug is the taillight. Twist it a quarter turn counter clockwise, and pop it out.
  4. 2000 Gmc Sierra Light Replacement: 手順 4、 1の画像 1
    • Remove the old bulb and replace it with your new one.
    • Side note: Make sure replacement bulb is save voltage/amperage rating.
    • Open the hood and take a look above your headlights.
    • Two metal pins holding each of the headlights in place will need to be removed (no tool necessary).
    • Turn the plastic headlight mount counter clockwise by one quarter of a turn.
    • Then lift the pins up to fully remove them.
    • Once the pins have been removed, GENTLY pull your headlight upwards, towards you. The bulbs should now be exposed. The bulb on the top is your headlight.
    • As you did with the taillight bulb, turn the piece that is holding the bulb in place a quarter turn counter clockwise, and the bulb will pop out. Now your new bulb will take it's place.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
keith beaudoin
メンバー登録日: 10/11/13
275 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 4-7, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-7, Vijaybhaskar Fall 2013人のメンバー
UMASSD-VIJAYBHASKAR-F13S4G7
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 500
