メインコンテンツにスキップ
2000-2007 Chevrolet Monte Carlo Negative Battery Terminal Disconnection
必要な工具と部品
  1. 2000-2007 Chevrolet Monte Carlo Negative Battery Terminal Disconnection, Hood Latch: 手順 1、 2の画像 1 2000-2007 Chevrolet Monte Carlo Negative Battery Terminal Disconnection, Hood Latch: 手順 1、 2の画像 2
    • Park the car on a flat surface, and remove the keys from the ignition.
    • Under the dashboard on the drivers side is the hood release latch. Pull this until you feel the latch release, the hood should pop up a little when this happens.
  2. 2000-2007 Chevrolet Monte Carlo Negative Battery Terminal Disconnection, Hood Release: 手順 2、 2の画像 1 2000-2007 Chevrolet Monte Carlo Negative Battery Terminal Disconnection, Hood Release: 手順 2、 2の画像 2
    • The hood should have popped up a little bit after pulling the hood latch, now you must release it before it can be opened.
    • Under the hood, slightly left-of-center is a release lever that must be pushed to open the hood all the way. This lever must be pushed to the right, in the direction of the car emblem.
    • Once you successfully release the hood, you should feel it try to rise up. These cars all have solenoids that assist in raising the hood. Simply lift the hood up, and it should stay up without any intervention.
  3. 2000-2007 Chevrolet Monte Carlo Negative Battery Terminal Disconnection, Negative Battery Terminal: 手順 3、 2の画像 1 2000-2007 Chevrolet Monte Carlo Negative Battery Terminal Disconnection, Negative Battery Terminal: 手順 3、 2の画像 2
    • The battery is on the left side of the engine compartment.
    • The cable connecting to the negative terminal should be black, and should have an exposed 8mm bolt head that screws into the battery. The negative terminal should also be marked on the battery.
    • Use an 8mm wrench to disconnect the negative terminal connector. Tuck the lose connector out of the way of the battery, so that it cannot make contact with the terminal.
    • Be very careful not to touch the positive battery terminal (with the wrench or yourself) while you're doing this. There should be a red protective cover on the positive terminal, but it's always good to take precautions. Shorting out a car battery will very likely result in a trip to the hospital.
    • New batteries tend to come with plastic plugs for the terminals. If you have these for your battery, this would be a good opportunity to use them. This will prevent anything from touching the terminal.
終わりに
作成者
1人の作成者と共同作成されました。
Chris Green
メンバー登録日: 10/11/09
35,740 ポイント
48のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
312 メンバー
1,330のガイドは作成済み
コメント 1 件
I have a black wire that was hanging from the wiring harness under the hood of my 2002 Chevy Monte Carlo ss. My door locks don't work & my fuses are burning out on both fuse boxes on each side of the dash. HELP PLEASE! Thank you, James.
Maxie Ortego - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 39
今までの合計 2,398
