メインコンテンツにスキップ
1999 Buick Century Window Regulator and Motor Replacement
必要な工具と部品
  1. 1999 Buick Century Window Regulator and Motor Replacement, Lower Window: 手順 1、 1の画像 1
    • Lower window to about ¾ of the way down or until the frame that the window sits on is visible in the lower opening.
  2. 1999 Buick Century Window Regulator and Motor Replacement, Disassemble Door Panel: 手順 2、 3の画像 1 1999 Buick Century Window Regulator and Motor Replacement, Disassemble Door Panel: 手順 2、 3の画像 2 1999 Buick Century Window Regulator and Motor Replacement, Disassemble Door Panel: 手順 2、 3の画像 3
    • Locate the 3 screws in the door.
    • 1 screw is in the door latch (phillips head)
    • The other 2 are in the door tray (10mm socket)
  3. 1999 Buick Century Window Regulator and Motor Replacement, Disassemble Door Panel (cont'd): 手順 3、 1の画像 1
    • Pry away the door (a flat head can be used as seen in the image, but any wedge like object would work.)
  4. 1999 Buick Century Window Regulator and Motor Replacement, Disconnect Necessary Cables: 手順 4、 2の画像 1 1999 Buick Century Window Regulator and Motor Replacement, Disconnect Necessary Cables: 手順 4、 2の画像 2
    • Tweeter Connection (circled in red)
    • Disconnect the tweeter connection where the red arrow is pointing.
    • Automatic Lock Connection (circled in green)
    • Disconnect the automatic lock connection from its location in the green circle.
  5. 1999 Buick Century Window Regulator and Motor Replacement, (Remove Plastic If Applicable): 手順 5、 2の画像 1 1999 Buick Century Window Regulator and Motor Replacement, (Remove Plastic If Applicable): 手順 5、 2の画像 2
    • If the internal door panel is covered with protective plastic, remove it before proceeding.
  6. 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor: 手順 6、 3の画像 1 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor: 手順 6、 3の画像 2 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor: 手順 6、 3の画像 3
    • Locate and remove the 3 screws holding the window motor in place (Wrench and 10mm socket needed).
    • Disconnect the window motor connection wiring.
    • Wedge in-between the outer shell of the door and the window to hold the window in place (be careful not to damage the window. May have to stick it in at an angle).
  7. 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor (cont'd): 手順 7、 3の画像 1 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor (cont'd): 手順 7、 3の画像 2 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor (cont'd): 手順 7、 3の画像 3
    • Locate and Remove the four 10mm screws below the interior door latch.
    • Locate and remove the two 10mm screws on the window frame.
    • Remove the motor and the regulator through the hole.
  8. 1999 Buick Century Window Regulator and Motor Replacement, Replace The Motor And The Regulator (Reassembly): 手順 8、 2の画像 1 1999 Buick Century Window Regulator and Motor Replacement, Replace The Motor And The Regulator (Reassembly): 手順 8、 2の画像 2
    • Follow steps in reverse order to connect the new window motor and regulator and to reassemble the door panel.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Gear Brothers
メンバー登録日: 11/21/16
221 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 4,648
