メインコンテンツにスキップ
1999-2001 Mazda Miata (MX-5) Door Speaker Replacement
必要な工具と部品
  1. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement, Door Speaker: 手順 1、 2の画像 1 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement, Door Speaker: 手順 1、 2の画像 2
    • The battery is in the right side of the rear cargo compartment. It can be found by moving the carpet and wood cover.
    • With a 10mm wrench, remove the positive battery terminal.
    • Do not let any metal in contact with the positive battery terminal contact any other metal item. This might make sparks.
  2. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 2、 3の画像 1 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 2、 3の画像 2 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 2、 3の画像 3
    • Remove the three trim panel retainer clips.
    • Old clips might break easily. Be extra careful when removing them or get spares.
  3. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 3、 3の画像 1 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 3、 3の画像 2 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 3、 3の画像 3
    • Remove the three screws that hold the door panel in place.
    • These screws are all different, so keep note of where they all go. The short screw goes in the door latch; the long screws go in the door handle.
  4. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 4、 2の画像 1 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 4、 2の画像 2
    • Remove the cover around the door latch by pulling the handle and rotating the cover.
  5. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 5、 2の画像 1 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 5、 2の画像 2
    • Remove the door panel by pulling the bottom out and lifting up.
  6. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 6、 3の画像 1 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 6、 3の画像 2 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 6、 3の画像 3
    • Remove the four screws holding the plastic speaker mount.
    • As you remove the screws, don't let the speaker fall out and pull the wire.
  7. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 7、 3の画像 1 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 7、 3の画像 2 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 手順 7、 3の画像 3
    • Detach the connector that powers the speaker by pressing down on the top latch and gently pulling.
    • A small screwdriver might help with the latch but be careful. Old plastic can be brittle.
終わりに
作成者
1人の作成者と共同作成されました。
Nathan J
メンバー登録日: 02/20/24
145 ポイント
1ガイドが承認済み
チーム
University of Arizona, Team 2-1, Cools Stephens Spring 2024 University of Arizona, Team 2-1, Cools Stephens Spring 2024人のメンバー
ARIZONA-COOLS STEPHENS-S24S2G1
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 38
今までの合計 110
