メインコンテンツにスキップ
1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement
必要な工具と部品
  1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Plastic Rain Tray: 手順 1、 1の画像 1
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 2、 1の画像 1
    • Remove the rubber gasket from the rain tray.
  3. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 3、 1の画像 1
    • Lift the tray upwards and away from the vehicle.
  4. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Front Windshield Wipers: 手順 4、 1の画像 1
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  5. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 5、 1の画像 1
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  6. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 6、 2の画像 1 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 6、 2の画像 2
    • Gently lift up the passenger-side windshield wiper.
  7. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 7、 1の画像 1
    • Remove the driver-side windshield wiper in the same fashion.
    My windshield wipers were stuck on like they were welded. I removed them with channel lock pliers. I put the top jaw of the pliers and placed it under the wiper and the bottom claw of the pliers and put it on the mounting bolt. squeezed as hard as I could and Pop! It came loose.
    Nils Stansen - 返信
  8. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: 手順 8、 2の画像 1 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: 手順 8、 2の画像 2
    • Lift up the plastic cover.
    There is a lip on the back side of the cowling. I placed a flat pry bar underneath the cowling from the engine compartment towards the windshield and used the flat lip of the firewall top edge to pry the cowling straight up; not forward or backward but straight up. Mine was stuck with years of debris that turned to a natural glue!
    Nils Stansen - 返信
  9. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 9、 2の画像 1 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 9、 2の画像 2
    • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
    • In a pinch, you can make this tool with a phillips driver bit and end wrench.
  10. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 10、 1の画像 1
    • Use a #2 Phillips screwdriver to remove the front two screws.
  11. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 11、 2の画像 1 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 11、 2の画像 2
    • Gently unplug and lift out the automatic transmission control unit.
終わりに
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Matthew Newsom
メンバー登録日: 01/05/10
39,500 ポイント
67のガイドは作成済み
5 件のコメント
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - 返信
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - 返信
got a question if your display light is dim what could be the problem
dean wafula - 返信
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - 返信
thank you very much .
emad_szs - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 34
過去 30 日: 146
今までの合計 43,694
