メインコンテンツにスキップ
1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement
必要な工具と部品
  1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Plastic Rain Tray: 手順 1、 1の画像 1
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 2、 1の画像 1
    • Remove the rubber gasket from the rain tray.
  3. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 3、 1の画像 1
    • Lift the tray upwards and away from the vehicle.
  4. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Front Windshield Wipers: 手順 4、 1の画像 1
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  5. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 5、 1の画像 1
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  6. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 6、 2の画像 1 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 6、 2の画像 2
    • Gently lift up the passenger-side windshield wiper.
  7. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 7、 1の画像 1
    • Remove the driver-side windshield wiper in the same fashion.
  8. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: 手順 8、 2の画像 1 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: 手順 8、 2の画像 2
    • Lift up the plastic cover.
  9. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 9、 2の画像 1 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 9、 2の画像 2
    • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
    • In a pinch, you can make this tool with a phillips driver bit and end wrench.
  10. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 10、 1の画像 1
    • Use a #2 Phillips screwdriver to remove the front two screws.
  11. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 11、 2の画像 1 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 手順 11、 2の画像 2
    • Gently unplug and lift out the automatic transmission control unit.
終わりに
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Matthew Newsom
メンバー登録日: 01/05/10
39,500 ポイント
67のガイドは作成済み
5 件のコメント
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - 返信
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - 返信
got a question if your display light is dim what could be the problem
dean wafula - 返信
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - 返信
thank you very much .
emad_szs - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 34
過去 30 日: 146
今までの合計 43,694
